***AMP SOLD*** Transcendent Sound Mini Beast and Balanced Power Supply
0 Members and 1 Guest are viewing this topic. Read 2002 times.
LostInPA
*** AMP SOLD - Balanced Power Supply to be separately listed*** A set consisting of one amplifier and one balanced power supply.   Actual photos shown.   Two shipping boxes, total weight approximately 55 pounds.    $1,300.00 plus shipping from ZIP 18661.
- Transcendent Sound Mini Beast, 4 WPC single end Class-A
OTL tubes. One higher than stock voltage capacitor, power switch now on back
panel, power transformers raised for better cooling.  Two damper “O” rings on every tube.  Some new spare tubes included.  Assembly manual included.  Found packaging.   No issues; never blew any fuses.
- Transcendent Sound “Balanced Power Supply” which is a 1
kva balanced power transformer plus a few small capacitors in an aluminum
enclosure.  Included is the as supplies
power strip.  Assembly manual
included.  Found Packaging.
« Last Edit: 12 Feb 2018, 03:22 pm by LostInPA »
gjo1314
Re: Transcendent Sound Mini Beast and Balanced Power Supply
« Reply #1 on: 22 Jan 2018, 04:51 pm »
Greetings
I'm  interested But  only in the amp, if you are offering it. Would like to match it with the Grounded Grid pre that I have.
George
