SOLD! - Network Fiber Optic setup - TP-Link Converters & 50 ft fiber optic cable
0 Members and 1 Guest are viewing this topic. Read 849 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
If you use ethernet for carrying music over your network, you may be introducing electrical noise from your router.  This system converts ethernet to fiber and back to ethernet.  This interrupts the electrical connection between the router and your music system so that none of that electrical noise can be transmitted to your system.  This will help in reducing the noise floor in the system and increasing that sense of a "black background" and, in turn, imaging and sense of realism.  The effect may be subtle or marked depending on the degree of noise present and the sensitivity/quality of your system components.
Included are two TP-Link MC100CM converters, power supplies, ~50ft of fiber optic cable, and instructions.  Retail is $95 total.  Will sell for $65 shipped anywhere in the US (phooey on you "conus only" sellers  :evil:).  That is $50 plus shipping and fees.  If you are outside the US, we can figure costs.
From TP-Link:
The MC100CM is a media converter designed to convert 100BASE-FX fiber to 100Base-TX copper media or vice versa. Designed under IEEE 802.3u 10/100Base-TX and 100Base-FX standards, the MC100CM is designed for use with multi-mode fiber cable utilizing the SC-Type connector. The MC100CM supports longwave (LX) laser specification at a full wire speed forwarding rate. It works at 850nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required) or with TP-LINK´s 19´´system chassis, Auto MDI/MDI-X for TX port, Auto negotiation of duplex mode on TX port, supports both 5VDC and 9VDC external power supply and front panel status LEDs. The MC100CM will transmit at extended fiber optic distances utilizing multi-mode fiber up to 2 kilometers(1.2 miles).
http://www.tp-link.com/us/products/details/cat-43_MC100CM.html
« Last Edit: 24 Dec 2017, 05:43 pm by pstrisik »
pstrisik
Sale Pending payment!
pstrisik
