Industry Circles
Bryston Limited
Pi help
Pi help
0 Members and 1 Guest are viewing this topic. Read 901 times.
schmidtmike76
Pi help
22 Dec 2017, 09:00 pm »
My Pi will play tidal but won’t play my media files. It shows on the dash board that the song is playing but the display still shows “TIDAL” and no sound is coming.
dB Cooper
Re: Pi help
22 Dec 2017, 09:03 pm »
Umm, this doesn't seem to have anything to do with Bryston per se, maybe it would be better for the Discless Circle?
schmidtmike76
Re: Pi help
Reply #2 on:
22 Dec 2017, 09:11 pm »
It says Mpd isn’t responding?
Larry Dickman
Restricted
Re: Pi help
Reply #3 on:
23 Dec 2017, 08:08 am »
I have found with no sound that the audio input setting is off--often it changes on its own--for example in Tidal it should be set to to my USB DAC or snd_rpi_hifiberry_digi or bcm2835 ALSA but for some reason that setting doesn't stick and changes to something that produces no sound.
schmidtmike76
Re: Pi help
Reply #4 on:
23 Dec 2017, 02:35 pm »
i did check that setting and it’s correct. It’s almost like it’s not reading from my iPad to the Pi. We know it is as tidal is working. I’m sure it’s a setting I nursed with trying to find the up address a couple of days ago.
Industry Circles
Bryston Limited
Pi help
