Kinetic Systems table top active anti vib system. Great turntable base!
0 Members and 1 Guest are viewing this topic. Read 949 times.
genestl
I have for sale, a New In the Box , never used, nor unpacked,  KSI (Kinetic Systems) anti-vibration work station.  I am asking $900 for it.
It is two feet by three feet and a few inches high. It is quite heavy too.
If somebody bought it,it would arrive in the manufacturers' original packaging which would be strapped to a pallet.
It is a KSI Model 2212-03-11
It is two feet by three feet and has a white plastic top. (think smooth formica)
It needs a source of compressed gas at up to 80 psi (pressure depends on weight) and I have a nitrogen bottle and regulator I could include(for an extra $150).  It goes through gas very slowly unless you put it in the back of a truck.  It only consumes gas when something wiggles it enough for the gas servos to isolate it. (Like if you press on the work surface with your thumb to satisfy yourself that its working, or there is an earthquake or a regular train shaking your building.)   The gas bottle (a small Nitrogen cylinder) would last a very long time.
These things are very expensive.  It would totally ice-o-late  your turn table. Or  your laser scanning confocal microscope or nanogram balance or , or...
http://www.kineticsystems.com/page.php/id/211
http://www.kineticsystems.com/page158.html
When you see a picture of them injecting a biological cell the microscope taking the picture is always on a table very much like this.  Those pictures are usually at 500 to 1200 x magnification and in watery media.  These systems isolate all the shakes.
Contact me by private message please.
« Last Edit: 28 Dec 2017, 08:53 pm by genestl »
genestl
https://www.soundsofsilence.com/vibraplane-platform/
Sounds of Silence sells these for $2500 , so $900 is likely as good a deal as you will run across.  New in box never used.
