0 Members and 1 Guest are viewing this topic. Read 3023 times.
I use the Disk Doctor brushes and cleaning solution, then I rinse them with the Spin Clean. (go halfway down the page to see it) http://www.garage-a-records.com/index.phpThen hand dry with lint free rags. It takes about 1 minute per record, is easy , cheap and silent.
...(or any other standard vaccum for that matter, just no shop vacs) ...
I totally agree with your choice of Disc Doctor fluid and brushes but this anti-Shop Vac statement has me puzzled. Please explain your reasoning....
By the way, I think the Disc Doc products are great but the velvet pads are poor and their adhesive can be attacked by the cleaning solution itself. I don't like the idea of that adhesive melting and soaking through the pad and mixing with the cleaning solution while it's on my record surface. I've had excellent results using the DD rubber brush blocks with a much larger piece of velvet fabric wrapped around the block and taped up by the handles. I bought and tested several samples of velvet fabrics from my local sewing center and discovered one that "feels" exactly like the original DD pad when scrubbing on the record surface. Not too thick, not too thin. The sonic results are excellent and the sale price is $10 per linear yard.
