Marantz 1150D Stereo Amplifier
0 Members and 1 Guest are viewing this topic. Read 2062 times.
s20000
« on: 17 Dec 2017, 09:58 pm »
This unit was recently tested by a reputable hifi audio service shop and everything is working up to specifications.
Up to spec in watts
Up to spec in Frequency
Phonograph working
Caps are fine
This is a vintage unit and described as warm, silky smooth. May bring back some memories running phono and vinyl. The Balance Knob is missing, however can be had for a minimal cost on Ebay.
$575 obo
Local pick up preferred in Las Vegas Area.
I would consider trading for a good tube preamp.
Power output: 75 watts per channel into 8? (stereo)
Frequency response: 15Hz to 50kHz
Total harmonic distortion: 0.1%
Input sensitivity: 1.8mV (MM), 180mV (line)
Signal to noise ratio: 78dB (MM), 88dB (line)
Output: 775mV (line)
Dimensions: 144 x 376 x
