3.7I placement in a 12 x 15 room
0 Members and 1 Guest are viewing this topic. Read 2115 times.
johnto
« on: 13 Dec 2017, 03:52 pm »
Pulled the trigger and upgraded from 1.7i to 3.7i Maggie's powered by a Parasound Halo integrated amp.
I'm looking for placement ideas from those with similar size room. Current set up 16" from side wall tweeter angled in 32" from rear wall and outside 43" from wall. Can't complain about sound  just checking for other possibilities. Speakers on 12' wall.
SteveFord
Re: 3.7I placement in a 12 x 15 room
« Reply #1 on: 14 Dec 2017, 11:26 pm »
A picture would help.
A good rule of thumb is around 4' out from the front wall and then get the ribbons pointed right at your ears.
I messed around with mine a few weeks ago and the sound went from it's okay to WOW!
Guess they got shoved around over the years and I didn't notice it.
jhm731
Roger Gustavsson
« Reply #3 on: 15 Dec 2017, 07:15 am »
Cardas setup must be a joke...
jhm731
« Reply #4 on: 15 Dec 2017, 07:38 am »
And you know this how?
Please provide some measurements.
A_shah
« Reply #5 on: 15 Dec 2017, 08:59 am »
Plus + 1
my 1.7i are about 9 feet apart toed in about 28 degrees room size L 34 feet but listening are about 20 feet 15 W ceiling 9 feet and then Vaulting ceiling into the dinning room and Kitchen area
listening sweet spot 12 feet from the speakers measurements done with lasers , SPL with Radio Shack meter strategically placed curtains and furniture no room treatment (WAF)
 I Have a Parasound Halo, but upgraded to Odyssey Kismet /Stratos, you may need to have  a higher current amp(60 amps ) you may find the Halo wanting in terms of power for the  3.7i, If I choose to upgrade to 3.7i I would probably go for two mono amps.
Roger Gustavsson
« Reply #6 on: 15 Dec 2017, 12:07 pm »
I have tried it in my room.
rollo
  • Rollo Audio Consulting -
« Reply #7 on: 15 Dec 2017, 05:31 pm »
  You have a narrow room. Set out from front wall 5'. Try tweeters on inside.  Deaden front wall. Diffuse rear wall. Set speakers 7' apart center to center. Start straight ahead then toe in gradually until it locks in.
Have fun.
charles
