FS: Von Schweikert Audio VR-35 Deluxe Export Loudspeakers $3250
0 Members and 1 Guest are viewing this topic. Read 1514 times.
ada
Von Schweikert VR-35's currently in my master bedroom as part of a video system. Very nice (not perfect, almost) pair of VR-35's, big brother to the cost conscious VR-33 released around 2010. Driven conservatively by a VTL ST-150 Tube Amplifier. Rated 8/10 because I never rate anything above an 8. Gloss/ Piano black tops and bases look super sharp. These VR-35's are in superb condition cosmetically and operate flawlessly. Speakers look new from only a couple feet. Carpet spikes and factory jumpers are included.
Price : $3250 + 3% paypal. Shipping arranged by Buyer. I will assist as necessary. Pictures available on US Audio Mart and AudiogoN.
"If you do not achieve "goose bumps" when you are listening to the VR-35 Export Deluxe speakers, you have not achieved their full potential — please call us or email for help."" - Enjoy the Music
"Von Schweikert Audio’s VR-35 Export Deluxe is a remarkable loudspeaker. It performed wonderfully, handling all musical genres with aplomb. " - SoundStage!
Specifications:
Type: Reference floorstanding loudspeaker
Frequency Response: 25 Hz to 30 kHz (+/- 3dB)
Sensitivity: 90dB/W/m
Impedance: 8 Ohms nominal, with a minimum of 5 Ohms @ 25 Hz.
Subwoofer: Scan-Design custom 10" with Low Distortion Motor, laminated composite cone, elevated spider, long throw design, and copper clad pole piece.
Midrange: Two Scan-Design 6" treated paper cast-frame bass-mids with low distortion motors, elevated spiders, copper clad pole pieces, and composite laminated cones using cellulose acetate pulp, plastic resin, and carbon impregnation to eliminate standing waves on the cone surface.
Tweeter: 1" treated fabric dome, Danish-designed Dual Ring design with rear chamber for low resonance and powerful response down to the midrange band, Low Distortion Motor, and custom voice coil/top plate design for low distortion.
Crossover: First order circuit using "audiophile-grade" parts, with cross points set at 80 Hz and 6 kHz. All crossover parts are made by Mundorf and Erse, with custom solid copper foil capacitors insulated with Teflon dielectric film.
Woofer Alignment: Quasi-transmission line design using three chambers, each tuned to a different resonant frequency to extend the bandwidth and reduce "one note bass" typical of ported boxes. Woofer "fires" at rear wall to boost the bass at 20 Hz by 3dB, and can be "tuned" by user.
Power Rating: 35 watts minimum, up to 500 watts on peak music.
Dimensions: 50 x 16 x 12 (HxWxD in inches)
Weight: 112 lbs. each
Warranty: 5 year
Price: US $ 7,995 per pair
Includes:
VSA Factory Boxes, Factory Jumpers and Carpet Spikes
« Last Edit: 13 Dec 2017, 10:05 pm by ada »
