FS: Manley NEO-CLASSIC SE/PP 300B $6000
0 Members and 1 Guest are viewing this topic. Read 1489 times.
S1NN3R
« on: 7 Dec 2017, 05:34 am »
As you can see from the box, shipped direct from Manley labs on July 2017. I bought it with out stock tubes. All tubes are upgraded and included, Quad matched Genelex Gold Lion PX300B, Tung-sol match 6SN7 and 6SL7, Tung-sol 5AR4 rectifiers. Upgraded main fuse and B+ fuse to HI-FI Supreme tuning fuses. Comes with all the original accessories and box. Like new condition. Shipping to 48 lower states only.
Vacuum Tubes: 2 x 300B (Output), 1 x 6SN7 (Driver), 1 x 6SL7 (Input),
2 x 5AR4 (Rectifier). (Units prior to 2011 used 5U4 rectifier tubes.)
Output Power @ 1kHz with 5 dB FeedBack in SINGLE-ENDED: 11 Watts @ 3% THD
Output Power @ 1kHz with 5 dB FeedBack in PUSH-PULL: 24 Watts @ 1.5% THD
Frequency Response with 5 dB FB in SINGLE-ENDED: 15 Hz - 15 kHz ±0.5 dB (measured at 5 watts)
Frequency Response with 5 dB FB in PUSH-PULL: 10 Hz - 20 kHz ±0.5 dB
GAIN SE Mode 0dB Feedback Setting: 30 dB
GAIN SE Mode 10dB Feedback Setting: 20 dB
Input Sensitivity with 5db FB SINGLE ENDED: 700mV for Maximum Power
Input Sensitivity with 5db FB PUSH-PULL: 450mV for Maximum Power
Input Sensitivity with 5db FB SINGLE ENDED: 165mV for 1V output into 8 Ohms
Input Sensitivity with 5db FB PUSH-PULL: 160mV for 1V output into 8 Ohms
S/N Ratio: SINGLE ENDED: 83.5dB Ref. 1W; 2.83v//8 Ohms,20KHz BW; 5dB FB.
S/N Ratio: PUSH-PULL: 85.4dB Ref. 1W; 2.83v//8 Ohms; 20KHz BW; 5dB FB.
Dynamic Range: SINGLE ENDED: 94dB Ref. 3% THD; 20KHz BW; 5dB FB.
Dynamic Range: PUSH-PULL: 99.5dB Ref. 1.5% THD; 20KHz BW; 5dB FB.
Input Impedance: 100 kOhm, direct coupled.
Optimum Speaker Load (switchable): 4 to 12 Ohm range appropriate for 4 & 8 Ohm speakers - 12 to 20 Ohm range appropriate for 16 Ohm speakers
Actual Output Impedance SINGLE ENDED: 2.25 Ohms
Actual Output Impedance PUSH-PULL: 1.86 Ohms
Damping Factor SINGLE ENDED: 3.5
Damping Factor PUSH-PULL: 4.3
Maximum Power Consumption: 240 Watts
Mains Voltage Frequency: 50~ 60Hz
Asking: $6000 OBO
Shipping: $200
I pay PalPal fee
Located at Bellevue WA
« Last Edit: 20 Feb 2018, 07:41 am by S1NN3R »
