Sold
0 Members and 1 Guest are viewing this topic. Read 739 times.
mattattnet
Sold
« on: 30 Nov 2017, 03:33 pm »
SOLD
Great Gallo subwoofer, very versatile, in full functional shape and near new esthetic condition.
Original manual, and stock power cable included.  Will ship in original box.
From the website:
The Gallo TR-3D subwoofer is a high-output, dynamic subwoofer which offers top notch performance and amazing bass equalization. It features an array of capabilities and precise bass control, with the rear panel providing continuously variable phase and low-pass frequency, as well as bass EQ from 0 to +3dB and +6dB, which transforms any room into a multiplex or an arena. This is a heavy piece of audio equipment as well, with a hardened steel housing that makes its build quality apparent.
The new Class D amp (with enough precise bass control to satisfy your exact tastes) is coupled with the Ceramic Anodized Aluminum Cone Long Throw 10” Driver and features our panted S2 bass loading technology. But we can throw out numbers and specs all day long – the proof is in the sound. And the TR-3D delivers. It sounds amazing – the bass is rich and deep, but never intrusive (unless, of course, you wish it to be – you “Bass People” know who you are, and you’ll love tweaking your new TR-3D to shake the room.) Bottom line: the TR-3D is a high quality subwoofer which sounds great with both music and movies, regardless of room size.
This speaker won a 2015 Editor’s Choice award at the Absolute Sound
Model   TR-3D
Frequency Response   18Hz to 180Hz +/- 3db
Power Handling   300 watts, 600 watts max, Class D Digital amp
Driver   10" Long Throw Ceramic Anodized Aluminum Cone
Dimensions   10.75" W x 12" H x 13.5" D
Cone Material   Ceramic Anodized Aluminum Cone
Enclosure Material   Hardened Steel with patented S2 bass loading
Warranty   2 Years Parts & Labor
Crossover   See below
Connections   2 Female RCA phono inputs and 2 female RCA phono outputs (pass thu), 5 way gold plated speaker level binding posts
Finish   Black
Phase   0/180 Switch
Low Pass   50 to 180Hz, continuously variable with LFE by-pass swirch
High Pass   100Hz fixed, 1st order high-level output
Bass EQ   0, +3dB, +6dB, 30Hz center frequency
Power Auto On/Off   Auto On/Off Toggle Switch
Gain   Dial
Tweeter   None
Weight   33 lbs
Woofers Cover   Black Metal Grill SEARCH ALL PRODUCTS
« Last Edit: 7 Dec 2017, 12:42 pm by mattattnet »
