0 Members and 1 Guest are viewing this topic. Read 1799 times.
1. Never leave tube equipment on when you are not home or nearby.2. Always use fuses of the correct value and definitely use one.3. When testing voltages, especially in tight spaces use probes with clips/hooks. Keep one had in your pocket.4. Always over specify DIY parts. Don't use old capacitors. When they blow it can be pretty exciting.5. Always check power wiring multiple times when connecting it up.
