NEW! Assembled ladder type 24-step 10K-Attenuator!
0 Members and 1 Guest are viewing this topic. Read 3314 times.
ken_diyzone.net
    • http://www.DigitalAnalogueDIY.com
« on: 20 Dec 2004, 04:58 pm »
Assembled 10K-Attenuator pictures
http://www.audio-wiki.com/gallery/
Assembled ladder type attenuator made from high quality 24-step 4-deck rotary switch, Dale RN60D resistors, OCC wire, and silver solder. This is an assembled stereo attenuator.
The price is $59 US, available for delivery now.
Please contact me at [email protected] (or [email protected]) for more information.
Ken Shih
Digital and Analogue DIY Audio
27 Upland Rd
Great Neck, NY 11020
516-729-3752
JoshK
« Reply #1 on: 20 Dec 2004, 05:01 pm »
Hi Ken,
You mention 10K here but the site says 100K.  Is it an option which load or is it just 10K or 100K?
ken_diyzone.net
« Reply #2 on: 20 Dec 2004, 05:13 pm »
Josh,
I have the 4 decks@10K's ready for shipping.  The 100K's and 8 deck ones are coming (bet you heard that one before :-))
Ken
BradJudy
« Reply #3 on: 20 Dec 2004, 05:28 pm »
Are these make-before-break switches (ie. do they not make a popping noise when rotated)?  Will 10k and 100k be the only 2 levels made or will there also be others?
ken_diyzone.net
« Reply #4 on: 20 Dec 2004, 06:13 pm »
I have to get back to you on the make-before-break question.
As for the levels, yes, 10K and 100K are the only ones we are making.
Ken
ken_diyzone.net
« Reply #5 on: 20 Dec 2004, 08:23 pm »
BradJudy,
And yes, it is make-before-break design.
Ken
tkp
« Reply #6 on: 20 Dec 2004, 10:08 pm »
Ken,
Do you plan to offer other values in the future such as 20K?
10K is a bit too low for tube equipment so 20K is the perfect choice for me.
and will there be a 48 step version?
TKP
ken_diyzone.net
« Reply #7 on: 20 Dec 2004, 10:22 pm »
Hi TKP.
Right now, we are only producing the 10K and the 100K 4 deck version.  We are almost ready to supply the 8 deck version, but only at the above two values as well.
And nope, no plans to do a 48 step version.
Ken
LordCloud
« Reply #8 on: 22 Dec 2004, 09:58 pm »
I am really interested since I am currently in the market for a new volume control for my tubed preamp. What are the dimensions, if it won't fit I can't use it. Thanks. And is 100k the standard for tube preamps? :D
LordCloud
« Reply #9 on: 22 Dec 2004, 11:33 pm »
How would you rate your attenuators in comparison to the Dact unit?
ken_diyzone.net
Dimensions for the attenuator
« Reply #10 on: 3 Jan 2005, 07:53 pm »
Diameter = 1.67”
Length = 1.85”
Shift = 1”
Shift Thread diameter = .35”
Please note I have the 4 deck@10K and the 4 deck@100K avalible for delivery right now.  The price is $59, plus flat fee of $6 for shipping and delivery,
Ken
ken_diyzone.net
« Reply #11 on: 3 Jan 2005, 07:58 pm »
LordCloud,
Yes, most of the tube preamp can use 100K.
Can't say comparing to DACT products, since I have not heard them in a A/B test.  But I can say we use DALE resistors, it is make-before-break design, OCC wires, and use silver solder all around.
Ken
tkp
« Reply #12 on: 3 Jan 2005, 08:09 pm »
Quote from: ken_diyzone.net
LordCloud,
Ken
Assuming the switch being use in the 4 deck volume control is a good kind, this volume control should outperform the DACT CT1/CT2 because the DACT is a series stepped atttenuator versus ladder type in this case.
LordCloud
« Reply #13 on: 4 Jan 2005, 06:30 pm »
Thanks guys.
LordCloud
« Reply #14 on: 4 Jan 2005, 09:25 pm »
After I get the new HDTV purchase out of the way, I'll be purchasing one of your 100k jobbies.
