Raspberry pi enclosure?
0 Members and 1 Guest are viewing this topic. Read 1450 times.
bsr
« on: 16 Nov 2017, 04:42 am »
What are people using?  Hard to tell if there is much difference in the offerings...
jk@home
Re: Raspberry pi enclosure?
« Reply #1 on: 16 Nov 2017, 12:22 pm »
Are you using a HAT with it? HiFiBerry sells some decent metal cases.
https://www.hifiberry.com/
richidoo
« Reply #2 on: 16 Nov 2017, 03:16 pm »
I use this one: https://smile.amazon.com/dp/B01F1PSFY6/  Nothing special.   Snap together plastic.
If you run a hat you need a bigger case, buy it from the hat seller.
mfsoa
« Reply #3 on: 18 Nov 2017, 01:53 pm »
Yup, the metal one from HiFiBerry is sweet. Makes the Pi/HAT look like a legit little piece of gear.
But if you go HAT for digital go for the Allo DigiOne.
Watch the case for that, though - my particular USB power cord adapters barely fit through the case to connect power. I'll have to Dremel it someday. Someday...
bsr
« Reply #4 on: 27 Nov 2017, 03:44 pm »
Thanks.  The steel one looks great but can’t quite stomach the price and mentions of reduced WiFi strength.  Ended up just getting a plastic one from Amazon.
