**SOLD**Bent Modular Preamp - custom with slagle formers inside $1475
0 Members and 1 Guest are viewing this topic. Read 2775 times.
Big Red Machine
Works great. Has remote volume, on-off, balance. Single ended only. But two outputs.
Basically this is a Bent Tap-X preamp broken down into 3 modules for flexibility. This is a custom version with slagle formers, not the resistive topology.
You connect the modules via fiber optic cables. The power is only for the display and the control of the volume when activated. So it is passive except for the volume circuit when activated.
$2000  $1750 $1475
http://www.bentaudio.com/DLFILES/MICROTAP-R1.pdf
I popped one cover to expose the slagle former inside:
« Last Edit: 29 Jan 2018, 03:17 pm by Big Red Machine »
Big Red Machine
Re: Bent Mirco-Tap Modular Preamp
« Reply #1 on: 15 Nov 2017, 01:41 am »
Photos:
Big Red Machine
« Reply #2 on: 20 Nov 2017, 11:26 pm »
bump
Big Red Machine
« Reply #3 on: 29 Nov 2017, 12:14 am »
get your slagle formers!!
PaulF70
« Reply #4 on: 29 Nov 2017, 02:21 am »
The information you posted says this is a resistive, not transformer or autoformer, -based line stage.
Big Red Machine
« Reply #5 on: 29 Nov 2017, 03:30 pm »
They are slagleformers. I should not have posted the manual language about resistor topology.
This unit is this custom unit:
« Last Edit: 19 Jan 2018, 05:51 pm by Big Red Machine »
Big Red Machine
posted a photo above of the slagle former inside one of the pods
Big Red Machine
bump
Big Red Machine
$1750 anyone?
Big Red Machine
bump
Big Red Machine
bump
Big Red Machine
Big Red Machine
Re: Bent Modular Preamp - custom with slagle formers inside $1475
« Reply #12 on: 15 Jan 2018, 02:11 am »
bump
Goosepond
  • Virna!
« Reply #13 on: 15 Jan 2018, 03:44 pm »
BRM,
Your Inbox is full!!!!!!
Gene
Big Red Machine
« Reply #14 on: 19 Jan 2018, 11:02 am »
cleared
Big Red Machine
« Reply #15 on: 25 Jan 2018, 01:38 am »
bump
