WTB: Amplifier repair
0 Members and 1 Guest are viewing this topic. Read 1443 times.
Gary_V
« on: 3 Nov 2017, 04:51 pm »
Hi, my amplifier all of the sudden has no output. In search of someone to repair, I live suburban Chicago. Any help on local or any other info is much appreciated..... Thanks
mresseguie
Re: WTB: Amplifier repair
« Reply #1 on: 3 Nov 2017, 05:15 pm »
Gary,
First of all, replace the fuse(s). Does this fix the problem?
Second:
How old is your amp? What brand/model is it?
Has a lot of dust accumulated inside?
Do you own a cat, and could it have peed inside? [Seriously.]
Third:
Is there a reset option?
Michael
Gary_V
« Reply #2 on: 3 Nov 2017, 05:50 pm »
 All the fuses are good, amplifier is 3 years old. I have no pets, took off the cover and is very clean inside. It is a jolida jd1501p, it seems to boot up normal, not in protect mode. Has zero output, nothing even when ear up to speaker. When turned on goes from flashing red to solid blue as normal. Might be missing a relay click when blue light appears, not really sure about that though. Thanks for help...
Gary_V
« Reply #3 on: 3 Nov 2017, 05:51 pm »
I've swapped pre amps with same result
Tubeburner
« Reply #4 on: 3 Nov 2017, 08:23 pm »
Call Jolida at (301) 953-2014. They have had some issues in the past and would know better than anyone what might cause this.
Good luck!
Gary_V
« Reply #5 on: 3 Nov 2017, 09:30 pm »
Thanks, will give that a try and see what they have to say...
sfox7076
« Reply #6 on: 4 Nov 2017, 03:10 am »
Do you have a Volt meter?
Gary_V
« Reply #7 on: 4 Nov 2017, 07:33 am »
Yes I do have a volt meter..
sfox7076
« Reply #8 on: 4 Nov 2017, 10:57 am »
See if you get any AC voltage across the speaker terminals.
Gary_V
« Reply #9 on: 4 Nov 2017, 01:58 pm »
No AC voltage across the speaker terminals...
Gary_V
« Reply #10 on: 7 Nov 2017, 02:38 am »
Looking maybe for local repair individuals contacts....
timind
  • permanent vacation
« Reply #11 on: 7 Nov 2017, 12:48 pm »
I just googled "Jolida Amplifier Repair Chicago" and found several repair facilities. Give it a try. :thumb:
Gary_V
« Reply #12 on: 8 Nov 2017, 11:25 pm »
Thanks, I did talk to 2 places from Google but was not able to find a repair for Jolida......
