0 Members and 1 Guest are viewing this topic. Read 9080 times.
Recommendations:1.) At the low end, the JBL LSR305 (street price $260/pair) is hard to ignore. I've had it here for extended listening and it's hard to fault at anywhere near it's price. Rated down to 41 Hz, plenty of guts for a medium sized space, but fits nicely on a desktop.2.) I love my Dynaudio BM5 MkIII's, but now discontinued. If replacing would look at the impeccable K&H Neumann 120 (street price $1400/pair) for a medium sized room or it's big brother (3-way) for large rooms. A consummate studio monitor.3.) At the top end, start looking at the ATC, JBL M2 (large/only a mother could love), Meridian, and PMC.
I was going to add the Dynaudio Actives but see that others beat me to it!For a really good value I would also check out the new active speakers from ELAC. Andrew Jones has done an amazing job at ELAC churning out excellent sounding high value speakers.https://www.elac.com/products/ (select "Active Loudspeaker") at the top of the page to narrow down the list.
As I understand it, active speakers can have either active x-overs or passive x-overs. With the passive x-overs, the master speaker is connected to the slave via speaker wire.But with both having the active x-overs, there is no speaker wire between the speakers. How does master ‘speak’ to the slave speaker. Bluetooth?
I think I can see where you're going Kenneth, and I think you have the right picture in your head, but it's disguised by "non-traditional" terminology. Or I'm totally missing your question... The traditional terminology as I understand it is:Active crossover filter comes before the amplifier, between the signal source (CD/preamp) and the power amplifier. Passive crossover filter comes after the power amplifier, between the amp and the driver. That's the basic, traditional difference between passive and active crossovers.An active speaker system uses separate power amplifiers for each individual driver. A passive speaker has one amplifier powering all the drivers through the passive crossover.Passive crossover uses high voltage parts, since the power amplifier puts out high voltage to power the drivers.Active crossover filter circuits use low voltage "signal level" parts, like 1/4W resistors, etc.
Just to clarify the lines of speakers that AJ has designed are Debut, Unifi and Adante.
Damn, don't remember doing a single one of those. Must be getting old.
