Marten Logans Renaissance 11-A Loudspeaker DSP - as New, , MustSell $ 4995 OBO
0 Members and 1 Guest are viewing this topic. Read 770 times.
Audiophile58
This Loudspeaker has been totally redesigned from top to bottom. The panel itself now used Aircraft grade Extruded Aluminum which brings noticeably more defined resolution and focus.With extras $10,500 .i am located in Ma. Just over the CT line they are still setup until sold. No reasonable offer refused.i have lowered my price must  pay  the mortgage .
The imaging  and transparency is Excellent .the 11A 13A, and 15A  all share exactly the same
Parts quality .every part of the build was carefully designed and now only name brand parts
It is like  having a totally modified speaker . This is a first 24 bit DSP processing for the Bass
It is totally seamless it use dual precision Aluminum woofers. Firing front and back this speaker disappears in room and is beautifull less then a  foot wide but plays Very Big  when call on. I have a big room and sit about 10 ft from speaker , very versatile once setup. I used a 65 watt integrated tube amp with Excellent results,as well as solid state. The Ice amps power everything from 300 Hz on down .
And powered  Bass by the  dual Bang Olufsen Ice amplifiers 550watts x2  having dual powered  Bass drivers per speaker. Now has the optional  Anthem room correction which I purchased with it very easy to use and dramatically makes any rooms Bass tight and tunefull in  room to below 28 Hz.
On back mid bass is adjustable as well ,A10 position adjustment for low bass below 100 hz .
The Crossover uses only the Top name brand parts ,Clarity capacitors,Mundorf, Jantzen Copper inductors from Denmark 1% Gold resistors, and on back WBT Top Gold Copper  speaker terminals .90 db efficient on the panel  the cabinet is a beautiful cherry veneer.
It is As new only 4 months old .I am out of work with a knee injury must sell .
I have this speaker priced very low ,can come down a little  possibly in price.
Boxes are big and weighs  almost 100 pounds per box .i would prefer to be picked up
I would give allowance for your travel . Please contact me with any question .
Serious inquiries only Please Thank you.p.s great feedback on Audiogon - Audioman58
« Last Edit: 3 Nov 2017, 05:24 pm by Audiophile58 »
nhpm510
  • Trading refs: A'gon, Emo boards same user name
Sorry to hear about your injury and need to sell.
You might want to list your location for local sale.
Audiophile58
Thank you ,I am in Ma
