Excel and Short Time Periods
0 Members and 1 Guest are viewing this topic. Read 2101 times.
Speedskater
  • Kevin
« on: 27 Oct 2017, 03:45 pm »
Excel and short time periods.
For race results I use a custom cell format of  m:ss.00  for times like 1:01.33 and 0:59.61.
While they display and print correctly, but when I go back to edit the cell it's 12:01 AM.
Is there any other way of entering time?
Re: Excel and Short Time Periods
« Reply #1 on: 27 Oct 2017, 07:23 pm »
Not much used format: 00h05m20s    23h59m30s
Speedskater
  • Kevin
« Reply #2 on: 27 Oct 2017, 11:19 pm »
It seems that no matter what format I use, it reverts back to 12:00 AM to 12:04 AM range.
« Reply #3 on: 27 Oct 2017, 11:45 pm »
Its W10?
Maybe due your PC time/date format is in the US time.
Doublej
« Reply #4 on: 28 Oct 2017, 12:05 am »
Excel Version?, 32 or 64 bit?,
OS version? 32 or 64 bit?
Same behavior on multiple files created from scratch?
Speedskater
  • Kevin
« Reply #5 on: 28 Oct 2017, 12:39 am »
Once again I failed to describe the problem.
If I enter a race time of 1:10.22 it will display that correctly.
If I enter a race time of 4:33.09 it will display that correctly.
But if later I go back to a cell to edit a time, I see 12:01AM and 12:04AM.
and I can't edit the fraction of a second.
 It maybe Excel 2007 but I can't find the about button. Although the XP version did the same thing.
« Reply #6 on: 28 Oct 2017, 12:42 am »
Sure the default is US format time by Excel or W requirement, you may change it anytime.
Doublej
« Reply #7 on: 28 Oct 2017, 11:41 am »
It does the same thing on Excel 2016.  I think its related to how Excel stores elapsed times as clock times. 4:33.09 is being stored as 12:04:33 AM or in your case just 12:04 AM which is why you see this when you go to edit it.
I believe you will notice similar issues with date entry. You can choose the display of a date but may see it differently in the edit box.
You can try different format types for the cells but I think it will still store x:xx.xx as a clock time no matter what format you choose.
The only way around it is to put a ' in front of the string. So you would enter the time as '4:33.09. Then when you go to edit it you will see '4:33.09 in the edit box.
In Excel 2016 it is smart enough to detect that it looks like a number you are trying to sort and thus sorts the field as a number.
Peter J
  • Hmmmm
« Reply #8 on: 28 Oct 2017, 03:12 pm »
What I know about Excel you could put in a thimble and rattle, but I've gotten help for some out-of-my-league problems from the super-nerds here: ( and I mean that in the most appreciative way).
http://www.mrexcel.com/
Speedskater
  • Kevin
« Reply #9 on: 28 Oct 2017, 04:14 pm »
My other option is to enter:
 '1:17.21  which will display as  1:17.21
But then it's just plain text.
Doublej
« Reply #10 on: 28 Oct 2017, 07:45 pm »
So? It's still can be searched and sorted.
