FS: Shiny Eyes 45-C3g amplifier with separate power supply
0 Members and 1 Guest are viewing this topic. Read 2822 times.
Abszero
  • SE DHT
Here is another audio gem from https://simplepleasuretubeamps.wordpress.com/stuff-for-sale/.
This is the “Shiny Eyes” 45-C3g DHT amplifier, built with care and to provide a rewarding sound. This is an audiophile amplifier and it is not for everyone. It delivers up to 2W output. These 2W sound bigger than it shows. It is indeed a 2,000,000 microWatts. It is meant to be used with high sensitivity speakers. I listened to its sound using recently built TangBand 1772-W8 full range driver speakers. These are 96 dB sensitivity and fills the 300sqft room. For concert levels,a 100dB+ speakers are required.
The amplifier has 4 and 8 ohms outputs  through a switch and Cardas binding posts.  The output transformer are James 6123HS and the interstage transformers  are  Lundahl LL2762. The 45 tubes filaments power is supplied through a Coleman regulator. Therefore there is a need to adjust the filaments every time the tubes are  replaced. A 5V high quality Simpson meter is used for this purpose. The amp comes with a manual where there are easy to follow instructions on how to adjust the filament voltage.
The power supply has a separate enclosure. The high voltage uses a Hammond 278X, high quality Chicago Standard Chokes 10H/180mA chokes and 6AX4 tube rectifiers. The setup is choke input for a better sounding amp. The high voltage delivered to the amp is measured and shown on a nice Simpson 500VDC panel meter. There are 3 raw, well filtered and regulated DC supplies : two for the 45 filaments and the third for the C3g filaments. The power is supplied to the main amp through an umbilical cord that carries only DC. The connector is Amphenol military grade. This way the AC is kept away from the main amp and the amplifier is dead quiet on my 96dB speakers.
All the components are high quality and audio grade where needed, such as Nichicon KG, Takman, Mills, Elna Cerafine, Clarity caps, ASC Oil caps, Mundorf Mlytics.
The amplifier comes with all the tubes : NOS 6AX4 – 2 pieces, pair of 45s test NOS RCA black plate and pair of C3g NOS Lorentz.
The amplifier shows a dominant 2nd Harmonic that confers the absolute astonishing sound of a DHT from that era. One of the picture shows the harmonics and THD and one can observe that the THD superimposes
 almost perfectly on the 2nd harmonic. The maximum THD is 3.8% at 2W ( naturally second harmonic), the frequency response is better than 20-20KHz +/-1dB, the input sensitivity is 0.8Vrms for 2W output, the input impedance is 51Kohms and the damping factor is 4 on 8 ohms.
The enclosures are hand made using American cheery nicely finish with 4 coats of Oil and Urethane, and sanded aluminum 1/8″ top plates.
Despite the fact that I tried to keep the cost as low as possible, the price of this amp is high because I didn’t cut corners when I’ve designed it.
This is a well built amp to last for a long time.( more of my work can be seen on simplepleasuretubeamps). I am very fond of the sound of the 45 tube and therefore I’ve built a few 45 amps and always pleased with the results.
I am asking $2800 plus shipping of two boxes 16x16x14" at 38 and 36 lbs from 06851.
Thank you for taking your time to read this.
« Last Edit: 22 Oct 2017, 02:13 am by Abszero »
Re: FS: Shiny Eyes 45-C3g amplifier with separate power supply
« Reply #1 on: 20 Oct 2017, 05:03 pm »
Wow great amp!! Too bad my FR driver is only 94dB.
This amp not expensive for the parts used and labour.
Welcome to AC, always nice have an tube amp builder on hand ))
« Last Edit: 20 Oct 2017, 07:46 pm by FullRangeMan »
happyrabbit
« Reply #2 on: 21 Oct 2017, 12:35 am »
A 45 SET without equal  :green:
I want to own it...
Abszero
  • SE DHT
« Reply #3 on: 22 Oct 2017, 02:15 am »
I want to own it...
You can Happyrabbit..;))
Abszero
  • SE DHT
« Reply #4 on: 2 Dec 2017, 08:08 pm »
Bump up!
Abszero
  • SE DHT
« Reply #5 on: 21 Dec 2017, 02:50 am »
Sold.
Derockster
« Reply #6 on: 21 Dec 2017, 09:02 am »
Congrats on your sale.
Abszero
  • SE DHT
« Reply #7 on: 21 Dec 2017, 11:50 am »
Thank you.
