SOLD: Turntable basics turntable mirrored protactor for cartridge alignment
0 Members and 1 Guest are viewing this topic. Read 977 times.
danvprod
$15 SOLD
http://www.turntablebasics.com/align.html
Alignment tool for sale. I purchased a best tractor and don't need this one.
« Last Edit: 15 May 2018, 12:52 am by danvprod »
danvprod
danvprod
danvprod
Grinnell
Standard or oversize spindle hole
danvprod
Standard, I believe. It fit on my Sony tts3000a and ar-xa turntables.
danvprod
rif
  • Not a cowboy
I've used one of these for years and it greatly simplifies and removes much of the frustration in setting up your cartridge.
sunnydaze
The TB website says that AR tables require an oversized hole........        :scratch:
Is it Baerwald or Lofgren B?
danvprod
Just pulled my order information. From the invoice:
ORDER DETAILS:
Item: Phono Cartridge Alignment Tool - Standard
Quantity: 1
Description: Phono Cartridge Alignment Tool - Standard
I am not positive what the alignment is. There is nothing printed on the guide like the current models.
sunnydaze
Measure the distance of the 2 null points, from spindle hole (center) to bulls-eye where the stylus rests.
Baerwald:      66mm and 121mm
Lofgren B:     70.3mm and 117.2mm
danvprod
Thank you!
It's Baerwald:      66mm and 121mm
