0 Members and 1 Guest are viewing this topic. Read 13939 times.
I dont think there is any question playing digital with an optimised CAPS computer with high end USB card running HQ player and quality DAC will kill any redbook player. Using HQ player and upsampling your files to 352 PCM or DSD raises this to even higher level, but it is a HUGE rabbit hole.
Well it depends. Depends on what you use. For me CD is better with transport.
To get digital to sound decent , you have to add extra components such as reclockers. Plus, you gotta be a damn near software engineer to control it all. The primary value of digital is convenience, not improved sound quality. Keep it simple -- a CD and a transport.
Re-clockers are needed to achieve good performance, but only for transports and jittery sources, like Sonos. Not needed for good USB or Ethernet digital sources.Steve N.
I think a fair paraphrase of his conclusion was that high resolution files could eclipse the sound quality of physical media, but only under ideal circumstances with well mastered material. Even then, the margin of superiority was slim. To quote, "For Cd resolution files, USB/networking decks like the recently reviewed LampizatOr Superkomputer (6,000 euros) or Lumin X1 (13,000 euros) do compete head on with the CDT2 Mk. II disc spinner. To my ears, the simply don't outperform it. They just match it."
After upgrading I find there is a lot of life left in CD. All depends on the quality of the original performance, and the mastering / remastering. Nothing matters nearly as much as that.
I hate to quote 6moons, but the sentence I would pay attention to is this:"If any conclusions can be drawn from so isolated a test, I'd suggest that production/mastering quality trumps sample rates by a fierce margin."And I would add that in order to "outperform" physical CD, they would have to figure out a way to get rid of the USB cable from server to outboard DD converter/bridge and also the spdif cable from bridge to outboard DAC. Then, it can be done IME
Yes digital has surpassed CD, check this article: MQA is the best, the DXD master is 2, and CD is at the bottom:https://www.audiostream.com/content/supplementary-listeners%E2%80%99-notes-2l-test-benchThe moral of the story is get the new iFi MQA Black Label DAC when it becomes available. Yo can always use your CDP as a transport.
