0 Members and 1 Guest are viewing this topic. Read 4354 times.
--------------------------------l X ----radiator-- ll ll ll ll ll ---doorl X ll-window------------------ l
Ed,Is this because of the room or because the Wedgie is inherently superior to the coax?Randy
The LGK's hold there own in the mid-range. And in a small untreated room the more limited off axis response of the 3" drivers can be an advantage.
Hi Randy, I can only tell you what I heard. The V1 (coax) is a great speaker, I really enjoyed them and my son is enjoying them now. The Wedgie is a special speaker, I can only assume this is due not only to the NEO3 but the LGKs as well. The Wedgie reproduces detail with great accuracy, they image like crazy. I seem to recall reading the reason the Wedgie works so well in a small room is at least partially due to the small diameter of the LGK, the closer driver centers is also supposed to help with the integration of the drivers. The result is supposed to be less interaction with the sidewalls, I would agree, but look to Danny for the true technical reasons.Best,Ed
