DAC-10H Driver Setup File for Windows 8.1
0 Members and 1 Guest are viewing this topic. Read 2216 times.
reillyzing
« on: 9 Oct 2017, 06:58 am »
Hi,
 I see driver setup downloads for Windows 7/10 and XP but have a Windows 8.1 computer . What can I do? Thanks..
rustydoglim
Re: DAC-10H Driver Setup File for Windows 8.1
« Reply #1 on: 9 Oct 2017, 10:26 am »
The same driver works for Windows 8
reillyzing
« Reply #2 on: 17 Oct 2017, 05:34 pm »
Rather than starting a new thread, I'll post my very newbie question here.. Is it safe to use a 10 foot, 16 AWG, 300V extension cord with the DAC-10H? This would be my only option for the time being, until I find an electrician.
This is what I have.
https://www.monoprice.com/product?c_id=102&cp_id=10228&cs_id=1022802&p_id=5300&seq=1&format=2
JackD
« Reply #3 on: 17 Oct 2017, 09:31 pm »
Thicker would be better but for now it will work with no problem.
Charles Calkins
« Reply #4 on: 17 Oct 2017, 09:50 pm »
 Hey Bro:
  Go to your local hardware store and buy a 12 gauge 3 prong out door extension cord. Should be orange colored.
                                               Cheers
                                             Charlie
Letitroll98
  • Too loud is just right
reillyzing
« Reply #6 on: 19 Oct 2017, 07:52 pm »
reillyzing
« Reply #7 on: 29 Oct 2017, 10:21 pm »
I used the extension cord for maybe an hour or two but then switched to headphones so I didn't have to. Thanks for the replies..
