0 Members and 1 Guest are viewing this topic. Read 6139 times.
Please be aware that most houses built using common methods are very leaky. The potential to run intoissues via sealing your house up without having control of the ‘ventilation’ portion of your HVAC are there. With that said, closed cell foam is a great addition to your house. Focusing on the rim/band joist of your house first is wise. Doing a flash and batt method where you spray 1” of foam followed up with batt insulation is the most cost effective. 1” will provide the seal necessary while the batt can provide the extra r-value. Spray foam is rather expensive.My .02
Have they solved the dry rot problem with blown insulation? Lots of places that used it in the 80's have suffered it. Regarding the flash and batt method: If the foam insulation is continuous it should be very effective (and remove the dry rot concern). Think of a styrofoam cup, it drops the scalding hot coffee temperature to warm with a very thin (continuous) layer of insulation.Surround your air handler with insulation (except for the air intake and exhaust ports which should both be vented to the outdoors). Personally I don't see the problem in gaming the cats. I killed two of wifey's show rabbits that stay in the attached garage by running our portable generator (with the doors open).
One possible caution if you're thinking of applying the foam insulation underneath your roof. Our friend did that and when I mentioned it to our roofer he said it can make it almost impossible, should there be a roof leak, to determine where the leak originates.
Yes, spray foam underneath a roof is a really bad idea for a variety of reasons. You can use rigid foam or Roxul (preferably the latter due to its fire resistance: there are fasteners available to hold it in place) underneath a roof with spacers between the insulation and roofing to allow the latter to dry and be accessible if necessary.
Blow-in insulation dry rotting? That's news to me. Can you cite some documentation regarding that, JLM? Cellulose blow-in, both dense pack and loose fill, is commonly used in high performance insulation packages on many structures today. As to the rabbits and cats, that seems like a really callous statement regardless of the emoticons.
