SOLD VFET Class A Amplifier, modeled on Pass Sony DIY VFET, $750/obo incl.
0 Members and 1 Guest are viewing this topic. Read 3659 times.
mattattnet
SOLD
I am the second owner of this VFET amplifier built in Thailand.  I am selling as I have concluded my amplifier comparison and have decided the system synergy with one of the other Pass/ First Watt amps is slightly better.  Condition 7/10 due to non commercial build.
It is utilizing the Pass DIY circuit to commemorate the Sony VFET.  It uses the front end circuitry of the 2015 Sony VFET Part 2 Pass circuit, which uses local feedback at the input circuitry.
It uses one set of Sony 2SK82 and 2SJ28 VFETs per channel for about 15 watts into 8 ohms and 20 watts into 4 ohms.  The VFETs are known for their musical triode tube-like sound.
Quoting the original buyer:
" The VFET is a complex circuit whose output stage consists of a pair of complementary power VFET followers biased into pure Class A mode.  Thes devices are the current gain stage of the amplifier, very linearly following  the musical signal produced by the voltage gain stage.  The voltage amplification is created through a complementary jfet cascode with low noise transistors multiplying the input voltage.  The design is extremely reliable.  It achieves a relaxed sound with a very organic character and dynamics beyond the expectations of the power rating.  2SK170BL, 2SJ74BL, ZTX450,, ZTX550, 2SK2013, 2SJ313, 2SK82, 2SJ28, IRF240, and IRFP9240 are used."
I find the gain of the amplifier to be similar to most of the First Watt voltage output amps like the Aleph J and F5.  The sound is a bit more tube like, and truly organic.  The noise floor is not as quiet as with the other PASS F and J clone amplifiers I have built myself, but the only self noise from the amp is a quiet 120hz hum noted with my ear to my 98db sensitive speakers, and it is not at all noticeable with music playing.
The amplifier has nicely symmetric mirrored circuitry in a clone of the FirstWatt amplifier chassis.  It runs warm, but easily passes the "5 second rule" even with an ambient room temperature of 76 degrees.
The amp draws about 1 amp of current, power consumption is maybe 180 watts.
Dimensions of the amp are: 17.25 x 15.25 x 6 inches.  29 pounds.
It will ship in a box with custom foam supports.
SHIPPING IS INCLUDED TO THE CONTINENTAL USA, NO OTHER SHIPPING CONSIDERED.
It is also for sale on other sites, so I reserve the right to end the ad at any time.
« Last Edit: 6 Oct 2017, 02:54 am by mattattnet »
