FS: Clayton Shaw's Velocity Bridge VB 1 | speaker tweak
0 Members and 1 Guest are viewing this topic. Read 1075 times.
acastos
Clayton Shaw's latest invention, the VB 1 is an interface stabilizer that mounts across your loudspeaker's input terminals.
The Velocity Bridge helps to optimize power transfer into the speaker's load characteristics, providing tighter, more defined bass and improved placement of instruments in the sound field with better definition and a sense of space around performers.
Further sonic improvements come from the termination of Radio Frequency Interference (RFI), for a cleaner and more refined treble range.
Factory terminated in spades.
Ships for free to US continental buyers only. Paypal adds 3% if used.
$95.
deadhead
Re: FS: Clayton Shaw's Velocity Bridge VB 1 | speaker tweak
« Reply #1 on: 29 Sep 2017, 07:35 pm »
This may be a silly question but here goes.  How does the speaker cable connect to the device? Does it just hang from the binding posts?
acastos
« Reply #2 on: 29 Sep 2017, 07:47 pm »
To attach, loosen the speaker nuts while holding the speaker cables in place, then pop the two spades of the VB 1 from the top in between the speaker spades and the speaker post, then tighten the nut so it clamps both spades in place.
You will hear a smoother, deeper, more organic sound, with less electronic glare and hash.
