Hugh, is this a dumb question?
0 Members and 1 Guest are viewing this topic. Read 1228 times.
jake3
« on: 16 Dec 2004, 12:39 am »
Can the GK-1 have 2 sets of outputs, switchable between the 2 using the relay for the home theatre bypass? I consider the HT bypass to be of no value, but would like to send the signal in 2 different directions (not simultaneously).
Would this be an easy mod, considering I havent yet purchased the kit?
I'll try and make this my last dumb question... :?
AKSA
« Reply #1 on: 16 Dec 2004, 07:35 am »
Hi Jake3,
Yes, it could be done, but there would be some rather messy wire bypassing on the board, but it's all possible.  You could use the sub-woofer output RCAs for the second set.
However, this would be your project, Jake, not mine!!    :lol:
Hugh
