bryston 28sst no power
0 Members and 1 Guest are viewing this topic. Read 1199 times.
markkingston
« on: 25 Sep 2017, 07:46 pm »
hi
one of my 28ssts won't power up. I've tried different power cords but there is no led on the back and I press the on button on the front it crackles and turns orange for a second and then nothing. the circuit breaker's on.
any thoughts appreciated.
cheers
m
  • The Demo is Everything!
    • http://www.bryston.com
Re: bryston 28sst no power
« Reply #1 on: 25 Sep 2017, 08:21 pm »
hi
cheers
m
Hi
Email Mike at Bryston - [email protected]
james
markkingston
« Reply #2 on: 29 Sep 2017, 12:35 am »
hi
e-mailed him a few days ago but no reply.
cheers
mk
JakeJ
« Reply #3 on: 29 Sep 2017, 12:45 am »
Dumb question - do you have full voltage at the wall receptacle?
Elizabeth
« Reply #4 on: 29 Sep 2017, 03:01 am »
My tiny poor little 4B-SST² when new was a pita to get t ostart up until I had fiddled with the remote power on, flipping switches in every way possible. THEN KABOOM it turned on.
Ever since I am very careful to always use the correct set of turn off pre (to remote turn off amp) then front amp switch, the rear.
I say this thinking maybe your remote turn on has shorted or ??
Have you checked the remote turn on wires. Swapped them from on 28 to the other?
Just a thought.
