FS: ANTIQUE SOUND LAB MG SI 15 DT INTEGRATED AMPLIFIER
0 Members and 1 Guest are viewing this topic. Read 1645 times.
dapoun
Good Day!
Offered here is the latest iteration of this wonderful integrated amp. Higher grade transformers, larger extruded aluminium chassis and better quality connectors. KT 88 output tubes with 15 /5 Watts of clean power per channel. Single ended class ‘A’ topology with triode and pentode operation. External bias adjustment with calibrated bias meter for convenience. Wide range biasing for other octal based output tubes. Line level subwoofer out puts included. Unit comes with Mullard output tubes(KT88)/input tubes (12AX7), that I purchased from Upscale Audio.
Great cosmetic conditions but will lean on the side of caution and give it an 7/10. Operation wise, flawless! This amp is quiet as a mouse church. Would prefer local sale, but can ship at buyers expense. Unit will be double boxed. Asking $690!
Don't hesitate to contact me should you have any questions.
Thank you.
sebrof
Re: FS: ANTIQUE SOUND LAB MG SI 15 DT INTEGRATED AMPLIFIER
« Reply #1 on: 24 Sep 2017, 10:12 pm »
Since you mentioned Local Sale, you may want to mention where that is.
dapoun
« Reply #2 on: 27 Sep 2017, 03:06 am »
Levittown, NY
