question re: LR1..
0 Members and 1 Guest are viewing this topic. Read 2328 times.
WEEZ
question re: LR1..
« on: 15 Dec 2004, 09:19 pm »
Hi,
I was surfing around the MAD website and noticed the Line Router- neat product!
My question: (well, two actually)-
1) what is the approximate size of this device? and,
2) is it available in all the colors (say, black with natural wood sides)?
I was thinking that it would be a neat and inexpensive way to direct the sources to a tape recorder on one output- and a pre-amp on the other output.
thanks,
WEEZ
Dr. Lloyd
    • http://www.mapletreeaudio.com
question re: LR1..
« Reply #1 on: 31 Dec 2004, 06:14 pm »
Sorry to be slow in answering your questions. I have been filling orders and not reading the forums for the past month. The LR1 is the same size as the PS 1 power supply--7" x 5" with an oversize front panel. The chassis is available in the standard MAD colors--red, black, yellow, orange. The front panel is black. There are no wood side panels but these can be added for an extra $15. You can have the labels customized to your system (e.g. the outputs can be "Spkrs" and "Headphones", etc.)
Best wishes for 2005,
Lloyd
WEEZ
question re: LR1..
« Reply #2 on: 2 Jan 2005, 12:35 am »
Thanks for the info- and a very happy and prosperous new year to you.
WEEZ
