Hi all! Newbie from HK
0 Members and 1 Guest are viewing this topic. Read 1034 times.
Vinceat852
« on: 24 Sep 2017, 09:09 am »
Hi all! I'm an absolute novice. Found my way here because I was googling for info on the TPA3116 amp. I'm using an old 5.1 connecting it to a 2.1 (sacrilege, I know!) and mostly trying to understand more. I'm mostly going to be buying Chinese boards for amps (I've got a sanwu 3116d2 2.1 incoming) until I've got the budget to upgrade other stuff. Thanks for all the helpful posts!
Now time to head back to lurking and head scratching. =]
JakeJ
Re: Hi all! Newbie from HK
« Reply #2 on: 24 Sep 2017, 12:29 pm »
Hi Vinceat852, welcome to AC!
Phil A
« Reply #3 on: 24 Sep 2017, 07:01 pm »
Welcome!
« Reply #4 on: 24 Sep 2017, 10:09 pm »
Welcome.
It's a great time to be a frugal audiophile.  $500 can get you good quality audio:  a $200 thumb drive sized DAC to your computer for a source;  spend $20/month to subscribe to Tidal for CD quality music;  add $300/pair quality active monitors for desktop/small room listening or find cheap chip amps and DIY speaker kits from Parts Express (for example).
« Reply #5 on: 25 Sep 2017, 01:42 am »
Greetings & Welcome to AC Vinceat    :thumb:
witchdoctor
« Reply #6 on: 25 Sep 2017, 01:17 pm »
You should look at JBL speakers like the LSR 305 or the Studio 230 in HK. They are very popular in Asia, particularly Japan.
http://www.jbl.com/hongkong.html
dB Cooper
« Reply #7 on: 25 Sep 2017, 02:06 pm »
Welcome to the sweet spot
