BDP-3 Digital Player Additions
0 Members and 1 Guest are viewing this topic. Read 3148 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 21 Sep 2017, 06:07 pm »
SUBJECT: BDP-3 Additions – WiFi & Internal Drive Option
September, 2017
Hi Folks
I am pleased to announce that there are too optional additions available for anyone ordering a ‘new’ Bryston BDP-3 Digital Player.
The additional options:
1.   Internal WiFI:
The WiFi is capable of up to 300Mbps 802.11n and will work with 802.11a/b/g/n wireless capable networks. Most if not all 802.11ac networks should be backwards compatible with one if not all of these versions.
2.   Internal Drive:
A 500 GB quality mSATA Solid State drive or 2TB SATA rotary hard drive.
The advantage of an internal SATA drive is it bypasses the typical SATA to USB conversion.
Please contact Bryston regarding pricing.
Bryston
« Last Edit: 21 Sep 2017, 11:02 pm by James Tanner »
zoom25
Re: BDP-3 Digital Player Additions
« Reply #1 on: 21 Sep 2017, 06:14 pm »
That's great to hear James. Internal Wifi was always on my wish list.
I think I remember asking you once about internal Wifi, and you (or maybe it was someone else) replied that Wifi added noise to the circuitry. Hence, the decision to go with the ethernet connection. Did you find this to be true with internal wifi since the last time we spoke about your prototype BDP-3?
Thanks.
« Reply #2 on: 21 Sep 2017, 06:22 pm »
Thanks.
Hi
Yes - with the new BDA-3 circuitry we have found that we can add the internal WiFi with external antennas and not have interference issues.
james
won ton on
« Reply #3 on: 21 Sep 2017, 07:53 pm »
RE internal WiFi , does that mean you don't need a ethernet cable connection.
« Reply #4 on: 21 Sep 2017, 09:33 pm »
Hi
Correct it will use WiFi wireless connection.
james
won ton on
« Reply #5 on: 21 Sep 2017, 10:04 pm »
That sounds great as my stereo is in the basement at the opposite end of the house from the computer.So if i hooked up the bdp-3 with the internal wifi and built in hard drive then used a bot to rip my cd's ,down loaded manic moose or other to an i pad or phone i'd be good without having to use the computer. That being the case i just have to get some money together.   Thanks for your quick reply.
M Leo
« Reply #6 on: 21 Sep 2017, 10:29 pm »
James
Will the "BDP-3" upgrade kit for the BDP2 provide the optional additions and future BDP-3 enhancements?
Mike
Grant Hill
« Reply #7 on: 22 Sep 2017, 07:34 am »
Hi James,
thanks for the info.
one question: why a 2TB drive instead of a bigger one (like 3TB)? drive's dimensions should be the same...
Best,
Carlo
« Reply #8 on: 22 Sep 2017, 10:42 am »
Hi James,
Best,
Carlo
No specific reason other then we felt 2TB was a reasonable library size.
james
Marius
« Reply #9 on: 22 Sep 2017, 12:24 pm »
September, 2017
Hi Folks
Bryston
Any particular reason you write 'new' instead of just plain new..? Are there any older 'new' BDP-3's?
Marius
« Reply #10 on: 22 Sep 2017, 03:00 pm »
Marius
Hi Marius
Yes we have a lot of BDP-3's out there already with no WiFi or factory installed internal drives.  The NEW refers to any NEW(ly) ordered BDP-3.
james
Xinon
« Reply #11 on: 22 Sep 2017, 04:04 pm »
Can the "new" internal wifi be bought separately and added to already sold units?
« Reply #12 on: 22 Sep 2017, 04:54 pm »
Hi
Not easily as it requires a number of different parts - new back board with holes drilled for 2 antenna's plus some cable rerouting.
james
Tympani
« Reply #13 on: 22 Sep 2017, 05:52 pm »
James
Mike
James, any answer to M.Leo's question? Considering upgrading my BDP-2
« Reply #14 on: 22 Sep 2017, 06:49 pm »
Yes I think we should be able to do that according to Chris.
james
Marius
« Reply #15 on: 24 Sep 2017, 07:52 pm »
Hi Marius
james
Thx James, Cool and appreciated.
Cheers Marius
XMAN
« Reply #16 on: 25 Sep 2017, 01:41 pm »
james
Would you have a price for the BDP 2 upgrade?
« Reply #17 on: 25 Sep 2017, 01:49 pm »
Check with Mike but I believe it is $1500 - [email protected]
james
bobf
« Reply #18 on: 25 Sep 2017, 11:08 pm »
September, 2017
Hi Folks
1.   Internal WiFI:
2.   Internal Drive:
Bryston
Hi James,
What is the cost for each of these options when ordering a new BDP3?
« Reply #19 on: 25 Sep 2017, 11:13 pm »
Hi James,
Hi
Still working on that but around $200 on the WiFi section.
james
