IC: Audio Alchemy DLC (Preamp) & Monolithic Power station
0 Members and 1 Guest are viewing this topic. Read 1611 times.
actimation
Audio Alchemy Digital Line Convertor (Preamp) & Monolithic Powerstation:  A great & unique digital preamp that is remote control. The preamp is quite versatile as there are 4 inputs and 2 outputs.  In addition, you can also change the right and left volume independently.  The Audio Alchemy Digital Line Converter was modified by Dusty Vawter (of Channel Island Audio) by soldering the power cable directly into the unit and allows it to be powered by the Monolithic Powerstation, which has resulted in lower floor noise!
http://www.audioreview.com/cat/amplification/preamplifiers/audio-alchemy/dlc/prd_118161_1591crx.aspx
Given how unique and capable it is, I am a bit hesitant to let it go.  Might be willing to part with at the right price.  Please PM if you are interested.
Re: IC: Audio Alchemy DLC (Preamp) & Monolithic Power station
« Reply #1 on: 21 Sep 2017, 12:11 pm »
All sales ads should have a price.
