Orchard Audio Releases Starkrimson Mono Ultra Premium: A New 500W GaN Amp
0 Members and 1 Guest are viewing this topic. Read 25255 times.
orchardaudio
    • Orchard Audio
Hello,
Pleasure meeting you.
My name is Leo and I am the mastermind behind Orchard Audio - www.orchardaudio.com. I hold multiple patents and have over a decade of engineering experience.
Today I would like to introduce all of you to CRISPIN. CRISPIN is a high performance stereo audio amplifier that was developed using Digital Amplifier Company's Class-D modules.
CRISPIN has just launched on Kickstarter - http://kck.st/2jE4e3C
Here is a picture of CRISPIN
Here are the CRISPIN Specifications:
  • Inputs: Gold Plated XLR (balanced) or Gold Plated RCA Connectors (single ended)
  • Input Impedance: 20kΩ
  • Outputs: Gold Plated 5-Way Banana Binding Posts
  • Full Bridge Outputs (8Ω): 100W (per channel), Ultra 125W (per channel)
  • Full Bridge Outputs (4Ω): 200W (per channel), Ultra 250W (per channel)
  • Signal to Noise Ratio (SNR): 117dB
  • Total Harmonic Distortion (THD): < 0.005%
  • Frequency Response: 0 – 100kHz
  • Damping Factor: >400
  • Enclosure: Steel (14" x 11" x 3")
  • Power Supply: High Efficiency Linear Transformer, Individual Rails for Left and Right Channels.
  • Other Features: DC Coupled, True-Balanced Output
Leonid (Leo) Ayzenshtat
www.facebook.com/orchardaudio
www.twitter.com/orchardaudio
www.instagram.com/orchardaudio
« Last Edit: 5 Jun 2024, 07:04 pm by orchardaudio »
Re: Orchard Audio and CRISPIN
« Reply #1 on: 19 Sep 2017, 09:45 pm »
Welcome Leo  :thumb:
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
« Reply #2 on: 19 Sep 2017, 10:01 pm »
Welcome to Audio Circle, Leo.  You'll find the participants here to be intelligent and knowledgeable.
Nice introduction.  Good luck with CRISPIN !
orchardaudio
    • Orchard Audio
« Reply #3 on: 22 Sep 2017, 07:50 pm »
Here are some unique features of CRISPIN:
  • The Maraschino Modules inside the CRISPIN unit are plugged into sockets. This means that in the future you will be able to upgrade your amplifier with the next generation technology instead of having to buy a whole new amplifier. With other manufacturers you would be forced to buy a whole new unit.
  • CRISPIN has an integrated linear power supply (toroid power transformer). This eliminates the need for having to buy a separate power supply.
  • All of CRIPIN’s connectors are mounted and soldered directly to the motherboard. This eliminates the need for wire harnesses.
  • Using a 4-layer motherboard allows CRISPIN to have all critical signals routed on inner layers and be shielded (protected) by large ground planes on the outer layers.
How do you like them apples?
Currently CRISPIN is available at a discount though our Kickstarter campaign - http://kck.st/2jE4e3C
« Last Edit: 22 Sep 2017, 09:13 pm by orchardaudio »
Phil A
« Reply #4 on: 23 Sep 2017, 12:38 am »
Welcome!
orchardaudio
    • Orchard Audio
« Reply #5 on: 24 Sep 2017, 07:41 pm »
« Reply #6 on: 25 Sep 2017, 10:51 am »
Hi,
How would be the Crispin sound quality at the 1-3W range where fullrange drivers operate?
« Reply #7 on: 25 Sep 2017, 11:18 am »
Positive/negative speaker binding posts look to be very close to each other.
« Reply #8 on: 25 Sep 2017, 11:44 am »
Well noted, it follow the board outputs as require direct coupling the post, if it concern I suggest wrap a rubber fusion tape on the posts or a smaller borne.
Just a idea.
orchardaudio
    • Orchard Audio
« Reply #9 on: 27 Sep 2017, 02:14 pm »
They are the standard .75 inches apart.
AmpDesigner333
« Reply #10 on: 27 Sep 2017, 02:44 pm »
Hi,
Sound at low levels is exceptional thanks to nearly 120dB SNR, low distortion, low output impedance, and 100kHz bandwidth.  Check out impressions of other Maraschino based amplifiers:
http://www.audiocircle.com/index.php?topic=127654.0
(Almost 30,000 pages reads so far)
-Tommy O
« Reply #11 on: 28 Sep 2017, 01:51 pm »
Thanks Tommy I glad to know it, seems a beautiful sound.
orchardaudio
    • Orchard Audio
« Reply #12 on: 29 Sep 2017, 03:05 pm »
I figured out a way to reduce manufacturing costs. Forwarding savings onto customers, price has been reduced.
« Reply #13 on: 29 Sep 2017, 03:15 pm »
Hi, what do you guys think?
I feel CRISPIN 100W is too powerful for my 94dB single fullrange speaker, any MINI CRISPIN brother as 30/50W would be most interesting to me, mainly for the lower price.
Just a idea :green:
*Scotty*
« Reply #14 on: 29 Sep 2017, 06:01 pm »
I don't see where the problem might come from. I have a full range speaker system that has 95dB sensitivity and I use a 108watt/8ohm amp with no issues. It is nice to have the headroom for some classical pieces. Tchiakovsky anyone.
Scotty
orchardaudio
    • Orchard Audio
« Reply #15 on: 29 Sep 2017, 07:09 pm »
Just a idea :green:
CRISPIN performs extremely well across all volume levels. Most audio is actually 1/8 to 1/10 of peak. This was taken into account when amp was designed.
orchardaudio
    • Orchard Audio
« Reply #16 on: 29 Sep 2017, 07:11 pm »
« Reply #17 on: 29 Sep 2017, 08:11 pm »
Scotty
I glad to know it, thanks boys.
orchardaudio
    • Orchard Audio
« Reply #18 on: 3 Oct 2017, 03:02 pm »
Bump...
orchardaudio
    • Orchard Audio
« Reply #19 on: 9 Oct 2017, 12:41 pm »
Only 12 days left:
