When did Scott Nixon change the Dackit to normal phase?
0 Members and 1 Guest are viewing this topic. Read 1481 times.
mshan
Anyone know when Scott Nixon changed his Dackit and Tubedac(+) to normal phase?
Hantra
Re: When did Scott Nixon change the Dackit to normal phase?
« Reply #1 on: 15 Dec 2004, 12:07 pm »
Quote from: mshan
Last I heard it was about 4 months ago.
EProvenzano
« Reply #2 on: 15 Dec 2004, 07:58 pm »
What sonic impact did this have?
Hantra
« Reply #3 on: 15 Dec 2004, 08:13 pm »
Quote from: EProvenzano
EP:
I don't think it had any really other than switching the phase.  Scott showed me the part he uses to do it, and it's about the size of a flea.  You could hold probably a couple hundred of them in one hand.  I don't see how he even solders that into place.  But that's precisely why he's the man, and I am teh suck when it comes to soldering.   :wink:
mshan
« Reply #4 on: 16 Dec 2004, 02:06 am »
Whether or not incorrect phase will be perceptible probably depends on the resolution of your playback system and whether or not the recording you are listening to made any attempt to preserve phase initially (I think a lot of recordings now may actually be a mixture of normal and inverted phase signals, so neither normal or inverted phase will be totally correct).
Assuming a recording that preserves natural phase and a playback system resolving enough to reproduce it, inverted phase would present itself like a singer seeming to inhale while singing something that is naturally produced by exhalation (your headphones / speakers produce a rarefraction where a compression of the sound wave is technically correct).
