SOLD: Darwin Silver Phono Cable -- RCA to DIN with ground.
0 Members and 1 Guest are viewing this topic. Read 591 times.
danvprod
$75 SOLD
Darwin silver phono interconnect cable with ground cable. Wonderful cable to connect to your turntable. With the separate ground wire to connect to your phono stage or preamp. Used, in the excellent condition. It is the same cable as the regular silver cable, but the phono cable has different skin jacket for better shield and separate ground wire to connect between phono stage or preamp
It has two very small AWG silver wires that are in huge Teflon tubes, those are hand wrapped with Teflon tape, which has hand wound copper foil over that.
I am selling, unfortunately, as it doesn't work well with my suspended table. I am not able to route the cable in such a way that it doesn't interact with the suspension. For a non-suspended table, or heavy suspended/damped table, it would be perfect.
« Last Edit: 15 May 2018, 12:53 am by danvprod »
danvprod
Re: Darwin Silver Phono Cable -- RCA to DIN with ground.
« Reply #1 on: 2 Oct 2017, 08:35 pm »
bump.
danvprod
Bump and drop price.
danvprod
Bump.
danvprod
Drop again.
