is LRC shielded?
0 Members and 1 Guest are viewing this topic. Read 1836 times.
vtpham
is LRC shielded?
« on: 14 Dec 2004, 08:11 pm »
I was thinking of upgrading my center to a LRC and wondering if it is shielded.
thx.
ctviggen
is LRC shielded?
« Reply #1 on: 14 Dec 2004, 09:02 pm »
I wonder if the RM30C is shielded?  (It doesn't cause any problems on my RPTV.)
John Casler
Re: is LRC shielded?
« Reply #2 on: 14 Dec 2004, 09:08 pm »
Quote from: vtpham
thx.
LRC can be ordered sheilded, but that is not the stock form.
None of the VMPS speakers are sheilded unless it is specified at ordering.
No additional charge for ordering the LRC sheilded.
ctviggen
is LRC shielded?
« Reply #3 on: 14 Dec 2004, 09:41 pm »
I would think that you would automatically shield those speakers that you know are typically used on top of TVs, such as the LRC and the RM30C.  In my case, I just assumed that the RM30C was shielded.  I don't know whether my RM30C is shielded or not, but it would be a bummer to get it home, plop it on top of the TV, and have the TV picture affected.  In my case, the RM30C does not appear to be affecting the picture.
shokunin
is LRC shielded?
« Reply #4 on: 14 Dec 2004, 10:11 pm »
is there a sonic degradation by going shielded?  I suspect that most people who would use the RM30C as a center would be using a RPTV or front projection or plasma.  Most of the RPTv's these days are DLP, LCD, LCOS, etc that don't suffer from color and convergence issues that a CRT would.   Plus, most of the electronics in a RPTV are located at the bottom of the television.
I wonder how effective ERS paper/cloth sheets would be in instances where there is some noticeable video degradation?
vtpham
is LRC shielded?
« Reply #5 on: 14 Dec 2004, 11:24 pm »
Thanks for the info.  Just the thing I needed.
jimmyp58
is LRC shielded?
« Reply #6 on: 15 Dec 2004, 01:30 am »
I have my LRC sitting atop my RPTV (it is actually on a support base) without any untoward effects.  It is not the shielded variety.
Jim
John Casler
is LRC shielded?
« Reply #7 on: 15 Dec 2004, 01:33 am »
Quote from: ctviggen
Hi Bob,
Just to clairify, most TVs that are large enough to "support" the size of the LRC and the RM30 don't need sheilding.
Only the "direct view" tube sets have that problem.  While a LRC can be used atop or below a 36" (largest direct view) it is far more likely it will be a front or rear projection TV (40" plus) which doesn't have the problem.
