Group of 11 6A3 Vacuum Tubes Plus One 6B4G Double Tested (One 6A3 Added)
0 Members and 1 Guest are viewing this topic. Read 943 times.
baileyler
GROUP OF TEN 6A3 VACUUM TUBES PLUS ONE 6B4G DOUBLE TESTED - $400
ONE MORE 6A3 ADDED TO MAKE 11 6A3 AND ONE 6B4G.  NO PRICE CHANGE.  DETAILS AT THE BOTTOM.
I am continuing to clean out some equipment and tubes, so I have this group of 6A3/6B4G tubes available.
Tubes #1-3 are National Union branded 6A3 with dates codes of KC, LR and PR.
Tubes #4 and #5 are both Ken Rad branded 6A3, but I cannot see any date codes.
Tube #6 is a Sylvania branded 6A3 with a date code of 2V.
Tube #7 is an Emerson branded 6A3 with a date code of FGP1.
Tubes #8 and #9 are Raytheon branded 6A3 with a common date code of C6 and have what appear to be original boxes (in poor shape).
Tube #10 is a 6A3 with no brand that I can see, but it has black glass and looks like a GE or Ken Rad made tube.
Tube #11 is the 6B4G, is Philco branded with an engraved base, and has a date code of 7O.  The base on this tube is ever so slightly loose.
Tubes #1-7 and #11 have dual connected plates, while tubes #8-10 have dual flat plates.  Tubes #4, #5 and #11 have spring filaments.
I first tested these tubes on my Westmore 501 (gov’t version of Triplett 3444) connected to a regulated power supply.
The Westmore has an odd setting for 6A3, so when testing the 6A3 I used the 2A3 setting at Vf of 6.3.
On the Westmore, the Gm reject point for 6A3 (2A3) is 2600 and average spec is 5200, and for 6B4G the Gm reject point for is 2200 and average spec is 4300.   I am not sure why this would be different since both tubes are electrically the same (only a different pinout).
I also tested these tubes for plate current on the Westmore.  While there is no Westmore spec for plate current, the settings on the Westmore indicate that the test parameters are 250 V plate and -40V grid bias.  The Class A plate current spec for 6A3/6B4G at 250 V plate and -45 V grid bias is 60 mA (zero signal).
The results are as follows:
Tube #1   5400/72 mA
Tube #2   5300/71 mA
Tube #3   4900/64 mA
Tube #4   4800/62 mA
Tube #5   4800/60 mA
Tube #6   5200/71 mA
Tube #7   5000/60 mA
Tube #8   4400/62 mA
Tube #9   5200/66 mA
Tube #10   5200/70 mA
Tube #11   5000/60 mA
I also screened the tubes on a reasonably calibrated B&K 747 connected to a regulated power supply.  Since the B&K 747 does not have a 4-pin socket, the 6A3 were tested as 6B4G using an adapter.  The “GOOD” scale on the B&K 747 ranges from a numerical value of about 68 to 120, but I can find no specific indication of what an “average new” tube should test.  I have tested several different “new in box” tubes, and my experience is that the “average new” number will vary based on the tube.  Also, the scale is also not very detailed, so the numbers I give are approximate (+/- 2).
Tube #1   115
Tube #2   115
Tube #3   108
Tube #4   100
Tube #5   102
Tube #6   112
Tube #7   104
Tube #8    99
Tube #9   108
Tube #10   115
Tube #11   106
All tubes were clean for shorts, leakage and gas on both testers.  I would note that a couple gave a very (very) slight grid emission reading when initially tested on the Westmore, but when retested that dropped to a normal reading (probably a little off gas that was captured by the flashing).
All in all, the results are very consistent between two very different testers.
While they all test nicely, all of the above have to be considered "used".
My strong preference is to sell as a group, but I might consider splitting them up for the right offer.
I also have lots of other tubes so feel free to ask about those as well.
I can provide additional pictures or info on request.
GENERAL TERMS AND CONDITIONS
Please note that these tubes are being sold "AS IS, WHERE IS". THERE ARE NO GUARANTEES OR WARRANTIES OF ANY TYPE, AND THERE ARE NO RETURNS OR REFUNDS.
I ONLY describe what I know about the tubes, and what I have tested for.  While my tube testers tend to be reliable, YOUR TUBE TESTER MAY GIVE A DIFFERENT RESULT THAN MINE, so please take that into account. In the event of a tube tester conflict, MY TUBE TESTER CONTROLS.
AS SUCH, PLEASE NOTE THAT I CANNOT GUARANTEE (OR EVEN REMOTELY PREDICT) HOW THESE TUBES WILL SOUND OR PERFORM IN YOUR EQUIPMENT.  ANY TEST RESULTS ARE ONLY PROVIDED AS AN INDICATION OF TUBE PERFORMANCE IN A VERY LIMITED (AND NON-IDEAL) ENVIRONMENT.  EXCEPT AS EXPRESSLY INDICATED IN THIS LISTING, I DISCLAIM ANY AND ALL REPRESENTATIONS, WARRANTIES AND LIABILITY WITH RESPECT TO THESE TUBES, OR RESPONSIBILITY FOR YOUR USE OF THEM.
Payment can be via money order/cashier's check/personal check but, except for US Postal Money Orders, all must clear my bank first. Cash is OK for a local transaction.
I also accept Paypal for convenience (but add 3% to the total for US, and 4% elsewhere). IF YOU PAY VIA PAYPAL, HOWEVER, A CONDITION OF YOUR PAYMENT IS THAT YOU EXPRESSLY WAIVE THE RIGHT TO FILE A PAYPAL CLAIM OR CHARGE BACK (but do retain the right to sue me in court should you so desire).
Shipping will be at the buyer’s expense. I prefer USPS Priority Mail, but that is up to the buyer. Insurance for full value is recommended, as I am not responsible for any damage in shipping or non-delivery (but will assist in processing any legitimate claim).  Each tube will individually wrapped in bubble wrap.  Shipping weight will likely be on the order of 3 lbs.
Please check my feedback on Ebay (ID=baileyler) and buy with confidence.
« Last Edit: 30 Nov 2017, 01:44 am by baileyler »
baileyler
Bump.
May consider some trade.  Feel free to inquire.
baileyler
Another bump.
Feel free to ask about a possible group of 2A3 as well.
baileyler
Still available.
Open to trade for things like Nordost speaker cables or ICs, a solid-state hard drive (500GB or larger), certain vacuum tubes (like 5992, 7408, 6087, ECC801s, CV1985, L63, KT90 and others), a Roku (or similar) device), and various other odds and ends.
baileyler
I'll try this again.
I found one more 6A3, so I will include it at no extra charge.
In fact, combine this with my 2A3 lot and I will take $100 off the total.
The extra 6A3 is a nice one - Philco engraved based, spring filament, internal support and tests at 5000/68 mA (only tested on the Westmore).
The tube is clean for shorts, leakage and gas on the Westmore.
That is now 11 6A3 and one 6B4G.
« Last Edit: 1 Dec 2017, 11:41 pm by baileyler »
