Industry Circles
NuPrime Audio
rustydoglim
Sta-9 and ac noise filter
r91085
14 Sep 2017, 04:11 am »
I got a power cable which includes ac noise filter function.
I use it on sta-9 and sound seems has some difference.
The sound seems become a little clean or remove something in music . I am not very sure what kind of difference is it .
But I feel the origin power cable sound better than new one with ac noise filter function even if mabye it got some nosie from power .
Dose sta-9 need another ac noise filter work with it ?
rustydoglim
Facilitator
ยป
Re: Sta-9 and ac noise filter
15 Sep 2017, 04:33 pm »
Impossible to answer this kind of question. The issue is your power line, which has nothing to do with STA-9. Sure, if your power line is very noisy, you would be better off with an AC noise filter.
Industry Circles
NuPrime Audio
rustydoglim
