BDP-3 => is the limitation to DSD-128 hardware or a software issue
0 Members and 1 Guest are viewing this topic. Read 3458 times.
Hoiman
I wonder if the BDP-3 will be able to play DSD-256 in the future, is this a software issue or hardware issue?
  • The Demo is Everything!
    • http://www.bryston.com
Its software but there is so little material available that we have not had much interest in it.
james
Hoiman
I have some, not that much, but is it comming in the future or you don't know yet?
Its a good question - we have a lot of contact with studios being Bryston and most are telling me that it looks like 96/24 is what most studios are moving towards.
Also I think there is a realization among many that the mastering and Production quality (no compression) is far more important that the sample rate used.
james
unincognito
    • bryston.com
technically its both, kind of
The BDP-2/3 will output up to DSD512, but only via DoP and most if not all DAC's only support DSD above 128 via using one of the native DSD protocols (not that DoP isn't pure DSD, it is).  Our next major release (S3.XX) will contains native DSD support for our BDA-3 and a handful of other DAC's which already have native support baked into the kernel.
MoPac
Quote from Chris:
[/quote]
Chris:
 Is the native DSD support only for the BDP-3?
unincognito
    • bryston.com
likely be BDP2&3
witchdoctor
james
EVERY major studio is converting their catlogs to MQA and Universal has announced they want future releases in MQA. 3 streaming services are on board, Tidal, Deezer and a new service from HD Tracks. The MQA ship has already sailed and in 12-24 months the number of MQA tracks available will leave DSD and hirez PCM in the dust. If you feel 96/24 is sonically better more power to you, this is just where the puck is going.
Notice the headline here and the use of "mass adoption" in the article:
http://musically.com/2017/09/04/major-labels-hi-res-audio/
CanadianMaestro
Yeah, and it is called the Titanic II.
Destined for the bottom of the audio junk heap.
Mass adoption? Mass stupidity, that's all.   :lol:
witchdoctor
Don't blame the witchdoctor, you should protest by not buying any more music from a label that supports MQA (good luck with that) :roll:
Hoiman
LOL  :thumb:
Mike-48
Leaving aside the question of MQA, which is being vigorously debated in other threads and places, people might be interested to hear what Anthony Cordesman of TAS said in a recent review of a high-end DAC.
When the only difference in recordings is the bit and sampling rate used by two different machines to record the same music at the same moment ... I find the sonic differences [above 96/24] are subtle and often musically insignificant compared to the choices made in microphone, mike placement, mix, and venue.
and
I have yet to hear a convincing demonstration that hi-res recordings above 24-bit/96kHz—or from PCM to DSD64 and 128—really improve musical realism in even the best players. Even when I feel I can hear a difference, it requires a level of attention to upper-octave detail that can detract from the musical listening experience, and the level of difference—real or imagined—has no impact on the other, far larger aspects of musical sound quality.
My more limited experience (but with a highly resolving system) says he's right.
Norton
I  have a Hugo2 DAC on loan.  My BDP1 is playing DSD256 with no problems.  It should follow then that the BDP3 too will play 256 today when partnered with a DAC capable of DoP at that rate.   Higher rate DSD replay is more a function of DAC compatibility than BDP capability.  Is there any reason though why a future MM upgrade inc. native DSD capability won't also apply to the BDP1?
Hoiman
Wow how do you do that, when I had the BDP-1 as a loaner it didn't play DSD at all.
Norton
MPD 19.21 (others may work), make sure your USB DAC is enabled in audio devices with DSD option ticked and that's about it.  Everything else is simply down to what your DAC is capable of.
« Last Edit: 25 Sep 2017, 03:51 pm by Norton »
