Decware Zen Torii MK III - classic integrated tube amp (SOLD)
0 Members and 1 Guest are viewing this topic. Read 1585 times.
onethousandanswers
Up for sale is my Decware Zen Torii MK III Integrated Tube Amplifier. Given the versatility I had planned on keeping it for a long while, but circumstances change. The web has numerous reviews and discussions on the Zen Torii with quite a following in the audiophile community. It is very versatile in terms of tweaking the sound with the bass and treble pots as well as use of different tubes. I used this as both an amp (with an external pre) as well as an integrated. This unit is in great condition with only a small scuff on the back left corner (tough to see in pictures).
The amp was built with a number of upgrades including a cherry Base ($100), VCAPS ($500) and a stepped attenuator ($150). I will also include a number of tubes to start those who like to roll, including:
EL34/6CA7: Svetlana Winged Cs (quad), JJs (quad-new in box), and a set of lightly used JJs (one of them was giving me problems, so I purchased a whole new quad rather than troubleshoot)
OC2: RCA (pair) / OB2 Raytheon (pair)
OA3: RCA (pair) / 0B3: Sylvania (pair)
6N1P/6DJ8/ECC88/6992: GE (pair), Philips (pair)
5U4G: GE (pair), Sovtek (pair)
Manual - http://www.decware.com/newsite/TORIIMK3Manual.pdf
Review - http://www.tonepublications.com/review/decware-zen-torii-mk-3-amplifier/
Asking $????. Lowball offers will be politely ignored. PayPal will add 3%. Ships from Northern Virginia.
SPECS
SPECIFICATIONS INPUT TUBE CHOICES: 6922, 6DJ8, 6N1P
OUTPUT TUBE CHOICES: EL34
INPUTS: 2 RCA TYPE INPUT JACKS FOR EACH CHANNEL
OUTPUTS: 1 PAIR HEAVY Gold BINDING POSTS PER CHANNEL
OUTPUT STAGE TOPOLOGY: GND-CATHODE TRANSFORMER
RKRLOAD PLATE TO PLATE: 6600 OHMS
IDLE CURRENT: 47 MILS PER
OUTPUT TUBE HIGH B+ VOLTAGE: 410 VDC
CHOKE REGULATED PER CHANNEL INPUT IMPEDANCE: 100 K OHMS
INPUT SENSITIVITY: FULL POWER @ 2.0 VOLTS
POWER INTO 3.5 OR 8 OHMS: 24.6 WATTS RMS PER CHANNEL
NOISE: -9d0dB
OPERATION: CLASS A1
GRID REGULATION: ONE OA3-OD3 PER CHANNEL
INPUT STAGE REGULATION: ONE VR75~VR150 PER CHANNEL
RECTIFICATION: ONE 5Y3GT or 5AR4 or 5U4 PER CHANNEL
INPUT STAGE: ONE 6N1P or 6922 or 6DJ8 PER CHANNEL
OUTPUT STAGE: TWO MATCHED EL34 PER CHANNEL
SIZE: 19-1/8 'WIDE x 13-3/4 "DEEP x 7-3/4 "HIGH
NET WEIGHT: 36.8 lbs.
WARRANTY: LIFETIME TO ORIGINAL OWNER / 90 DAYS ON TUBES
« Last Edit: 14 Sep 2017, 03:05 am by onethousandanswers »
