0 Members and 1 Guest are viewing this topic. Read 6608 times.
"The budget for now is about 200€ for the Fullrange." each ?
I agree, Jordans are also good OB drivers. Unfortunately I have not heard a pair of the new Eikona drivers. I would like to but don't think it will fit in with what I am working on at the moment. Maybe someday in the future.
If you are ever in the South Florida area, let me know. I would be glad to demo them in my OB setup. The Eikonas have a similar personality to the JX92s, but are a little more dynamic with a clearer top end (i own both). The new ScanSpeak motor is also a big improvement over the first generation; they are able to play louder with less distortion. I actually have mine running full range with no highpass. At my listening levels, the intermodulation distortion isn't bad at all.
With apologies to DeeAlfred, are you willing to describe what you are working on currently?
If you could stretch your budget just a little bit, consider the Fostex FX120 or the FE-108E Sigma full range drivers.https://www.madisoundspeakerstore.com/approx-5-fullrange/fostex-fx120-5-full-range/https://www.madisoundspeakerstore.com/approx-4-fullrange/fostex-fe108ez-4-full-range-sigma-series/Implement an acoustic crossover (using passive or active electrical crossovers will work) at about 200 Hz on both the woofer and the full range driver. This will produce a relatively inexpensive OB speaker system that will perform well above its price point. Make sure you use a SS amp if you plan on using a passive crossover.
the b200 will drill the head and you will need 4 alpha
FF85wk, Alpair 7.3/6.2/5.2 will all work. The A7.3 in particular is outstanding.dave
Paper cones have a organic sound that is more enjoyable than alu and mainly plastics.
