BCD-3 gain
0 Members and 1 Guest are viewing this topic. Read 1544 times.
sweetspot
BCD-3 gain
« on: 7 Sep 2017, 02:07 pm »
James, I was wondering if the gain on the new BCD-3 is adjustable as it is on the BCD-1 via the BR-2 remote.I prefer the sound with my Bp-25p set at 29db in balanced mode.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BCD-3 gain
« Reply #1 on: 7 Sep 2017, 04:01 pm »
I am not sure - I will ask.
james
Re: BCD-3 gain
« Reply #2 on: 7 Sep 2017, 04:10 pm »
Hi
I checked and it is not currently possible - would require a software change.
james
sweetspot
Re: BCD-3 gain
« Reply #3 on: 7 Sep 2017, 04:16 pm »
Thanks james
CanadianMaestro
Re: BCD-3 gain
« Reply #4 on: 7 Sep 2017, 07:55 pm »
Whoa!!! How do I adjust gain from BR2?
Have had BCD-1 and BR2 for 6 yrs now, and never knew about this.... :duh: :duh:
sweetspot
Re: BCD-3 gain
« Reply #5 on: 7 Sep 2017, 08:17 pm »
BR-2 remote codes:  250-0db
                               251-1db
                               252-2db
                               253-3db
    Not a big change.                  Cheers
srb
Re: BCD-3 gain
« Reply #6 on: 7 Sep 2017, 08:19 pm »
Apparently you haven't read the BCD-1 Owner's Manual in 6 years! (page 3)  ;)
sweetspot
Re: BCD-3 gain
« Reply #7 on: 7 Sep 2017, 08:23 pm »
Those codes were only mentioned in regards to the BDA-1.
CanadianMaestro
Re: BCD-3 gain
« Reply #8 on: 7 Sep 2017, 08:24 pm »
Music makes me dyslexic   :wink:
@sweetspot: thanks for the codes -- I agree, probably little diff with such small dB changes. The 14B2 amp has a 6-dB change -- 23 or 29 dB gain. Very nice.  :thumb:
R. Daneel
Re: BCD-3 gain
« Reply #9 on: 11 Sep 2017, 05:47 pm »
I should point out this feature is not a gain adjustment. It is in fact a digital bit truncation that was implemented because the Cirrus Logic CS4398 DAC chip used in BCD-1 and BDA-1 has a higher output voltage than usual. In case your preamplifier has a problem with it, you can reduce the output level by 3 dB. This is an inherent feature of the CS4398 as a matter of fact. I think the datasheet stated it allows for a -60 dB level reduction but Bryston might have limited it to -3 dB to preserve audio integrity.
I don't think there would be a noticeable drop in performance  if you reduced the level by 3 dB but I would still rather use the volume control on the preamplifier.
This is also the reason why BDA-1 has a higher SNR than BDA-2. It is also the reason why CS4398 is favored among tube enthusiasts as it is a voltage output DAC rather than a current one.
Cheers!
Antun
