TC Sounds VMP 12" Passive Radiator - $24.
0 Members and 1 Guest are viewing this topic. Read 1518 times.
mritschdorff
« on: 5 Sep 2017, 03:18 pm »
The VMP 12" passive radiator is designed to allow up to 3.5" peak-to-peak excursion and to be easily adjustable, so that you can get the most out of your small enclosure passive radiator design. This is a passive radiator type speaker - it does not have a voice coil. 10 are available - there is a volume discount if you take all 10. All are new and in original shipping box.
« Last Edit: 3 Apr 2018, 11:41 am by mritschdorff »
Bob Stark
Re: TC Sounds VMP 12" Passive Radiator - $24.
« Reply #1 on: 6 Sep 2017, 01:55 am »
Would I be right in the passive company is VMPS, not VMP?  If so , you might get more traffic if it's corrected.
srb
ZAKski288
« Reply #3 on: 6 Sep 2017, 04:46 am »
Where are you located ? Thanks Zak
Early B.
« Reply #4 on: 7 Sep 2017, 06:45 pm »
I have the 15" version. Very high quality build. This is a steal.
mritschdorff
« Reply #5 on: 12 Sep 2017, 11:33 am »
Bump
mritschdorff
« Reply #6 on: 25 Sep 2017, 07:13 pm »
Bump
