SOLD! Emotiva XPA-2 Amp - Price Reduced $475.
0 Members and 1 Guest are viewing this topic. Read 1380 times.
mritschdorff
« on: 5 Sep 2017, 02:24 pm »
This XPA-2 Gen 2 is in excellent condition and sounds wonderful!
Number of channels: 2
Amplifier Class: Short signal path A/B
Output design: Triple Darlington with ON semiconductor output stages
Differential Drive: Dual Differential input
Types of inputs: Both Balanced (XLR) and Un-balanced (RCA)
Type of outputs: 5 way binding post
Display type: Digital VU meters
Metering: 14) Blue LEDS and 1) red per channel
Power output: 250 watts RMS/ channel into 8 ohms, 500 watts RMS/ channel into 4 ohms and 1,000 watts RMS bridged.
THD+N at rated power output: 0.007%
S/N ratio: >100db
Frequency response: 10 to 120Khz (-3db) and 20 to 20 (with less than .15db deviation)
Gain structure: 32db
Transformer size: 1600va mounted in a super structure
Secondary capacitance: 120,000uF
Massive aluminum heat sinks running the length of the amp ensure cool operation and amp longevity
Weight: Approximately 75 pounds
17” W x 7.75” H x 19” D
« Last Edit: 5 Oct 2017, 02:16 pm by mritschdorff »
mritschdorff
Re: Emotiva XPA-2 Amp - $500.
« Reply #1 on: 13 Sep 2017, 12:18 am »
Bump
taigovinda
« Reply #2 on: 15 Sep 2017, 10:57 pm »
Where are you located?  Thanks.
Tai
mritschdorff
« Reply #3 on: 16 Sep 2017, 01:01 pm »
Pontiac, Michigan
mritschdorff
Re: Emotiva XPA-2 Amp - Price Reduced $475.
« Reply #4 on: 20 Sep 2017, 02:24 pm »
Bump -Price Reduction
taigovinda
« Reply #5 on: 22 Sep 2017, 02:06 am »
Hi, you mentioned gen 2 but your picture and specs seem to be for a gen 1.  Can you confirm?  Thanks.
Tai
mritschdorff
« Reply #6 on: 22 Sep 2017, 02:45 pm »
It is a Generation 1 amp.
Marty
