Rest to factory?
0 Members and 1 Guest are viewing this topic. Read 1274 times.
Camper
Rest to factory?
« on: 1 Sep 2017, 01:44 pm »
Question for Chris.  Is there any benefit of resetting my BDP-1/2 to factory settings then updating to the latest software?  After years of updating the software are there files that are no longer used?  Kinda like reloading an operating system on a computer to make it run faster.  Any thoughts?
Camper
Re: Rest to factory?
« Reply #1 on: 3 Sep 2017, 04:22 pm »
Anybody do this?
Grit
  • - Garrett
« Reply #2 on: 5 Sep 2017, 03:15 am »
i never have, and i have never had any problems with my BDP-2.
gdayton
« Reply #3 on: 5 Sep 2017, 02:17 pm »
It's rare that you would have to reset to factory after a firmware update. In general, once you have settings that work for you, there should not be a need to reset to factory unless you are having trouble or are directed to do so by one of us in service.
Best,
Gary
unincognito
    • bryston.com
« Reply #4 on: 6 Sep 2017, 04:24 pm »
Anybody do this?
no not really, the only issue we ever had was with early releases of the TIDAL app.  Really there shouldn't be any need to perform a factory reset, i do it once and awhile but only to test a build in that state.
