2B SST2 vs 2.5B SST2
0 Members and 1 Guest are viewing this topic. Read 2466 times.
R. Daneel
« on: 26 Aug 2017, 11:43 am »
Hello!
Can anybody enlighten me as to what the differences between a 2B SST2 and 2.5B SST2 are? Apart from the slight increase in power output on the latter of course.
Cheers!
Antun
R. Daneel
Re: 2B SST2 vs 2.5B SST2
« Reply #1 on: 27 Aug 2017, 07:53 am »
Anybody?
gbaby
« Reply #2 on: 28 Aug 2017, 01:36 pm »
Hello!
Cheers!
Antun
The differences are the 2B has 100 wpc and the 2.5 has 135wpc and newer circuits.
PierreB
« Reply #3 on: 28 Aug 2017, 04:45 pm »
I think the difference is not the wpc.
My 2B SST has 143w/c.
Have you email James Tanner ?
gbaby
« Reply #4 on: 29 Aug 2017, 02:59 pm »
Your unit may have measured at 143 wpc, but spec out at 100 wpc. :nono:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 29 Aug 2017, 03:39 pm »
HI
OK checked with engineering.
The 2B SST2 was rated at 100 watts.
The 2.5B was rated at 135 watts
The 2.5 Cubed is rated at 135 watts but has the new Cubed input circuitry.
james
R. Daneel
« Reply #6 on: 3 Sep 2017, 09:54 am »
OK, thanks for all your replies!
I found a mint condition 2B SST2 at a very reasonable price so I am thinking about buying it. 100 Watts a channel would be more than enough power for me. I am not a fan of big amplifiers because my system isn't placed in a big room and because I rarely listen to music loudly.
I also know that Bryston amplifiers typically deliver 10% or even more power than their spec-sheets suggest.
