Please suggest SS stereo integrated amp
0 Members and 1 Guest are viewing this topic. Read 2049 times.
James Romeyn
« on: 26 Aug 2017, 12:05 am »
This is not for primary use, but still, the better is performance the more desirable is your suggestion.  Bass cutoff is only to 80 Hz in this application.
Required:
  • Reliable
  • Remote mute OR at least three remote inputs
  • SS only, no valves
  • Remote input selection OR remote polarity switch
  • One or more balanced input OR remote polarity switch
  • Volume control (prefer remote but not required), no other controls required, really, none
  • 50W minimum @ 8 Ohm, 6 Ohm minimum, easy phase angles, IOW only one easy load requiring only moderate current
I only mention the remote polarity switch in case of an odd unknown amp.  Maximum new SRP about $750.  Used OK.  Please do suggest something unheard if you suspect it worth considering.
« Last Edit: 26 Aug 2017, 03:16 am by James Romeyn »
Mr Peabody
Re: Please suggest SS stereo integrated amp
« Reply #1 on: 27 Aug 2017, 02:58 am »
I'm not sure what you mean in your requirement list, like if "remote input" is 12v trigger or analog inputs.  Most amps provide a mute.  In your budget new you're looking at Cambridge Audio or NAD both would have a variety, I lean toward Cambridge as the more reliable.  There's also Marantz, if you could find a model to meet your needs, probably the most reliable of the 3.
JackD
« Reply #2 on: 27 Aug 2017, 04:22 am »
Since your in the "industry" too, why don't you just contact John Casler and work out a deal on a Nuprime IDA-8?  Otherwise what Mr. P said plus Yamaha.
James Romeyn
« Reply #3 on: 27 Aug 2017, 05:13 am »
To what number to do you refer in my list of requirements?  I just re-read the list.  I'm curious which number you imply can be confused with a remote trigger.
James Romeyn
« Reply #4 on: 27 Aug 2017, 05:19 am »
No balanced input.
geowak
« Reply #5 on: 27 Aug 2017, 07:18 am »
Parasound Halo. https://www.stereophile.com/content/parasound-halo-integrated-integrated-amplifier
But it will cost around $2,500. Very nice selection.
timind
  • permanent vacation
« Reply #6 on: 27 Aug 2017, 11:03 am »
Used Primare I30 integrated would meet your needs. Very close to your price range.
Mr Peabody
« Reply #7 on: 27 Aug 2017, 02:25 pm »
2.Remote mute OR at least three remote inputs
Wind Chaser
« Reply #8 on: 27 Aug 2017, 02:35 pm »
No balanced input.
Isn't that something you could emend with a little DIY?
