0 Members and 1 Guest are viewing this topic. Read 8676 times.
Self explanatory. Any help appreciated!
One that matches your amplification, table and tonearm, then your musical tastes. Actually want some help? Then provide enough valid information to make that possible. Otherwise...."How long is a piece of string?"Cheers,Geary
I just put a Linn Krystal on my turntable. It's amazing. Nothing I have used has come close to it.
...Have I provided enough valid information?
Unfortunately, no. Playing vinyl requires a system in which components are correctly matched. Not possible to credibly offer suggestions without the system information. There are just too many iterations. Perhaps spending some time learning what is required in a vinyl playback system would be a good starting point. Then you could narrow down the possibilities and get some valid recommendations.Taking "recommendations" from someone that does not ask the basic questions is foolhardy. Likely they have little understanding of what they have or why they like it. Again, since we are talking analog, an analogy..."What are the best tires for my vehicle under $2000?"Cheers,Geary
I would call and ask for Chad Stelly at Acoustic Sounds. He is one of the few that actually get it IMO. Otherwise, a HANA Shibata might be the most cartridge out there for the money. I would strongly recommend trying this one before plunking $2K.
That's what I ended up going for --will keep you posted.
