Looking for Class D amp for small entertainment center
0 Members and 1 Guest are viewing this topic. Read 633 times.
Bubel
Greetings!
I need some help in recommendation for small $25-50 Chinese class D amp to put in in arcade cabinet witch can be used for movies and music.
Possible to get more bass for less $.
I plan to buy some 4 Ohms cars speakers and listening distance will be very short.
PCB and some simple soldering is OK as long as I can purchase components from China/Hong Kong.
My last choice was Breeze Audio TPA3116 but I heard it should be modded to lower the gain - the nice feature I`d like to have..
Is there detailed instruction how to do that?
Or maybe there other amps witch not pretty loud without any modifications?
JerryM
  • Where's The Bar?
Re: Looking for Class D amp for small entertainment center
« Reply #1 on: 18 Aug 2017, 06:01 pm »
Welcome to AudioCircle, Bubel.  :beer:
Make sure to check out the Cheap and Cheerful HiFi Circle.
Phil A
« Reply #2 on: 18 Aug 2017, 06:59 pm »
Welcome!
